Metals - Specific Heats
The specific heat of metals and metalloids (semimetals) are given in the table below.
See also tabulated values for gases, food and foodstuff, common liquids and fluids, common solids and other common substances as well as values of molar specific heat for common organic substances and inorganic substances.
Metal | Specific Heat - cp - (kJ/kgK) |
Aluminum | 0.91 |
Antimony | 0.21 |
Barium | 0.20 |
Beryllium | 1.83 |
Bismuth | 0.13 |
Cadmium | 0.23 |
Calcium | 0.63 |
Carbon Steel | 0.49 |
Cast Iron | 0.46 |
Cesium | 0.24 |
Chromium | 0.46 |
Cobalt | 0.42 |
Copper | 0.39 |
Gallium | 0.37 |
Germanium | 0.32 |
Gold | 0.13 |
Hafnium | 0.14 |
Indium | 0.24 |
Iridium | 0.13 |
Iron | 0.45 |
Lanthanum | 0.195 |
Lead | 0.13 |
Lithium | 3.57 |
Lutetium | 0.15 |
Magnesium | 1.05 |
Manganese | 0.48 |
Mercury | 0.14 |
Molybdenum | 0.25 |
Nickel | 0.44 |
Niobium (Columbium) | 0.27 |
Osmium | 0.13 |
Palladium | 0.24 |
Platinum | 0.13 |
Plutonium | 0.13 |
Potassium | 0.75 |
Rhenium | 0.14 |
Rhodium | 0.24 |
Rubidium | 0.36 |
Ruthenium | 0.24 |
Scandium | 0.57 |
Selenium | 0.32 |
Silicon | 0.71 |
Silver | 0.23 |
Sodium | 1.21 |
Strontium | 0.30 |
Tantalum | 0.14 |
Thallium | 0.13 |
Thorium | 0.13 |
Tin | 0.21 |
Titanium | 0.54 |
Tungsten | 0.13 |
Uranium | 0.12 |
Vanadium | 0.39 |
Yttrium | 0.30 |
Zinc | 0.39 |
Zirconium | 0.27 |
Wrought Iron | 0.50 |
Metalloids - also known as semimetals - are elements containing properties similar and midway between metals and nonmetals.
- 1 J/(kg K) = 2.389×10-4 kcal/(kg oC) = 2.389×10-4 Btu/lbmoF
- 1 kJ/kgK = 0.2389 kcal/(kg oC) = 0.2389 Btu/lbmoF = 103 J/(kg oC) = 1 J/(g oC)
- 1 Btu/lbmoF = 4186.8 J/ (kg K) = 1 kcal/(kg oC)
- 1 kcal/(kg oC) = 4186.8 J/ (kg K) = 1 Btu/lbmoF
For conversion of units, use the Specific heat online unit converter.
See also tabulated values for Gases, Food and foodstuff, Common liquids and fluids, Common solids and other Common substances as well as values of molar specific heat for common organic substances and inorganic substances.
Heating Energy
The energy required to heat a product can be calculated as
q = cp m dt (1)
q = heat required (kJ)
cp = specific heat (kJ/kg K, kJ/kg C°)
dt = temperature difference (K, C°)
Example - Heating Carbon Steel
2 kg of carbon steel is heated from 20 oC to 100 oC. The specific heat of carbon steel is 0.49 kJ/kgC° and the heat required can be calculated as
q = (0.49 kJ/kg oC) (2 kg) ((100 oC) - (20 oC))
= 78.4 (kJ)
• Thermodynamics
Aluminum - Thermophysical Properties
Density, specific heat and thermal conductivity related to temperature.
Aluminum Alloys - Mechanical Properties
Mechanical properties of aluminum alloys - tensile strength, yield strength and more.
Chromium - Specific Heat and Thermal Conductivities vs. Temperatures
Specific heat and thermal conductivity of chromium related to temperature.
Heat Capacity
Heat, Work and Energy
Heat vs. work vs. energy.
Iron - Density, Specific Heats and Thermal Conductivities vs. Temperatures
Specific heat, density and thermal conductivity of iron related to temperature.
Lead Binary Eutectic Alloys - Melting Points
Pb - Lead (Plumbum) - binary eutectic alloys and melting points.
Magnesium Binary Eutectic Alloys - Melting Points
Mg - Magnesium - binary eutectic alloys and melting points.
Metals - Boiling Temperatures
Metals and their boiling temperatures.
Metals - Latent Heat of Melting
Metals and their latent heat of fusion.
Metals - Machinability
The machinability of some common metals.
Metals and Alloys - Densities
Mixing Fluids
Final mass and temperature when mixing fluids.
Poisson's Ratios Metals
Polymers - Specific Heats
Specific heat of polymers like epoxy, PET, polycarbonate and more.
Solids - Specific Heats
Solids and Metals - Specific Gravities
Specific gravity for common solids and metals like aluminum, asbestos, brass, calcium and many others.
Specific Heat of Common Materials – Engineering Reference
Standard State and Enthalpy of Formation, Gibbs Free Energy of Formation, Entropy and Heat Capacity
Definition and explanation of the terms standard state and standard enthalpy of formation, with listing of values for standard enthalpy and Gibbs free energy of formation, as well as standard entropy and molar heat capacity, of 370 inorganic compounds.
