Iron - Density, Specific Heats and Thermal Conductivities vs. Temperatures
T
(K)
ρ
(kg/m³)
c
(kJ/kg K)
k
(W/m K)
100 7900 0.216 134
150 7890 0.324 104
200 7880 0.384 94
250 7870 0.422 87
300 7860 0.450 80
400 7830 0.491 70
600 7760 0.555 55
800 7690 0.692 43
1000 7650 1.034 32
1200 7620 28
1400 7520 31
1600 7420
1800 7420
Material Properties
Cast Iron
The four basic types of cast iron - white iron, gray iron, ductile iron and malleable iron.
Cast Iron Soil Pipes - Dimensions
Dimensions of cast iron soil pipes.
Metals - Latent Heat of Melting
Metals and their latent heat of fusion.
Metals - Specific Heats
Metals and Alloys - Densities
Metals Strength vs. Temperature
The influence of temperature on the strength of metals.
