Water Systems
Butterfly Valves - Sizing and Selection
Selecting and sizing butterfly valves for water applications.
Centrifugal Pumps - Capacity Modulation
Modulating pumps to adapt capacities to variable process demands.
Cold Water Dwellings - Storage Capacities
Required cold water dwelling storage capacity - commonly used fixtures and types of buildings.
Cold Water Storage per Occupant
Cold water storage for occupants in common types of buildings as factories, hospitals, houses and more
Control Valves for Water Flow – Kv Sizing & Pressure Drop Calculations
Control valve sizing and pressure drop calculations for water flow applications. Different valve types, Kv flow coefficients, and how to select the right valves.
Copper Tubes - Heat Losses
Heat loss from uninsulated copper tubes vs. temperature differences between tube and air.
Copper Tubes - Maximum Water Velocities
Water velocity in a copper tube should not exceed certain limits to avoid erosion.
Copper Tubes - Uninsulated Heat Losses
Heat loss from uninsulated copper pipes - dimensions ranging 1/2 - 4 inches.
Copper Tubes Type K, L and M - Working Pressures vs. Size
Domestic Hot Water Heaters - Sizing
Domestic Hot-Water sizing equations - heating capacity, recovery rate and power supply.
Domestic Hot Water Service Systems - Design Procedures
Design procedures for domestic hot water service systems.
Domestic Service Water Supply Systems
Introduction to general design of domestic service water supply systems - with pressurized or gravity tanks.
Domestic Water Supply - Lime Deposits
Lime deposited vs. temperature and water consumption.
Farm Livestock - Animals and Water Consumption
Average daily water consumption of various farm animals, including cattle, horses, sheep, and poultry.
Fixture Water Consumption and Required Water Supply
Supply requirements for common fixtures.
Fixtures - Hot Water Content
Content of hot water in some common used fixtures - basins, sinks and baths.
Fixtures Hot Water Consumption
Hot water consumption of fixtures like basins, showers, sinks and baths.
Fixtures Trap Sizes
Recommended drain trap sizes for different types of fixtures
Hoses - Water Volume Discharge Flow vs. Pressure
Water discharge through hoses - pressure ranging 10 - 200 psi (0.75 - 14 bar).
Hot and Cold Water Pipes Sizing
Recommended dimensions hot and cold water pipes.
Hot Water Circulation System - Return Pipes
Hot water can be circulated through a return pipe if it's instantly required at the fixtures.
Hot Water Consumption vs. Occupants
Consumption of hot water per person or occupant.
Hot Water Storage Tanks - Capacities vs. Dimensions
Dimensions and capacities of hot-water storage tanks.
Hot Water Supply - Flow Rates to Fixtures
Hot water consumption of some common equipment as basins, sinks, baths and showers.
Insulated Copper Tubes - Heat Loss
Heat loss to surrounding air from insulated copper tubes.
Laminar vs. Turbulent Flow - Reynolds Number Explained with Calculator
Nozzles - Water Discharge Capacities
Discharge capacities of water nozzles.
Open Horizontal Pipes - Discharge Length vs. Volume Flow
Discharge length vs. volume flow from water filled horizontal pipes.
Draw P&ID diagrams online in the browser with Google Docs.
Pipes - Insulated Heat Loss Diagrams
Heat loss (W/m) from 1/2 to 6 inches insulated pipes - ranging insulation thickness 10 to 80 mm and temperature differences 20 to 180 degC.
PVC Pipes Schedule 40 - Friction Loss vs. Water Flow Diagrams
Friction loss (psi/100 ft) and velocity for water flow in plastic PVC pipe schedule 40.
Required Water Supply to Public Buildings
Water consumption and supply to public buildings.
Stainless Steel Classifications
Stainless steels are commonly grouped into martensitic stainless steels, ferritic stainless steels, austenitic stainless steels, duplex (ferritic-austenitic) stainless steels, and precipitation-hardening stainless steels.
Steel Pipe Flanges for Waterworks Services
Trap Sizes vs. Fixture Units
No. of fixture units and required trap size.
Vertical Pipes - Discharge Height vs. Volume Flow
Volume flow and discharge height from vertical water pipes.
Water - Dynamic and Kinematic Viscosity at Various Temperatures and Pressures
Ionization constant (= dissociation constant = self-ionization constant = ion product = autoprotolysis constant ) of water and heavy water, given as function of temperature (°C and °F) in figures and tables.
Water - Max. Suction Flow Velocities vs. Pipe Size
Recommended max. water flow velocities on suction sides of pumps.
Water - Prandtl Number vs. Temperature and Pressure
Figures and tables with Prandtl Number of liquid and gaseous water at varying temperarure and pressure, SI and Imperial units.
Water Consumption and Activities
Typical human activities and average water consumption
Water Distribution Pipes - Materials
Materials used in water distribution pipes.
Water Flow - Max. Delivery Velocity vs. Pipe Size
Recommended maximum flow velocities in water systems on the delivery side of the pump.
Water Hammer
Rapidly closing or opening valves - or starting stopping pumps - may cause pressure transients in pipelines known as surge or water hammer.
Water Properties: Vaporization Heat vs. Temperature - Charts and Calculator
Water Service Pipe Lines
Water service pipe lines extends from the potable water source to the interior of buildings.
Calculating expected demand for water supply service lines.
Water Supply Fixture Units - WSFU vs. GPM and Liters/sec
Converting WSFU - Water Supply Fixture Units - to GPM.
Water Supply Lines - Sizing
Sizing water supply service and distribution lines based on Water Supply Fixture Units (WSFU).
Water Supply Systems - Impurity Limits
Typiclal limits for impurities in drinking water.
Water Systems - Maximum Flow Velocities
Water velocities in pipes and tubes should not exceed certain limits.
Water Vapor Saturation Pressure: Data, Tables & Calculator
Yard Fixtures - Water Consumption
Water consumption in garden fixtures.
