Nozzles - Water Discharge Capacities
Water discharge capacity through nozzles:
- water temperature 60 oF (15.6 oC)
- 1 in (inch) = 25.4 mm
- 1 psi (lb/in2) = 144 psf (lbf/ft2) = 6,894.8 Pa (N/m2) = 6.895×10-3 N/mm2 = 6.895×10-2 bar = 27.71 in H2O at 61 oF (16.7 oC) = 703.1 mm H2O at 61 oF (16.7 oC) = 2.0416 in mercury at 61 oF (16.7 oC) = 51.8 mm mercury at 61 oF (16.7 oC) = 703.6 kg/m2 = 0.06895 atm = 2.307 ft H2O
- 1 gal (US)/min (gpm) =6.30888×10-5 m3/s = 0.227 m3/h
• Water Systems
Hoses - Water Volume Discharge Flow vs. Pressure
Water discharge through hoses - pressure ranging 10 - 200 psi (0.75 - 14 bar).
Open Horizontal Pipes - Discharge Length vs. Volume Flow
Discharge length vs. volume flow from water filled horizontal pipes.
Vertical Pipes - Discharge Height vs. Volume Flow
Volume flow and discharge height from vertical water pipes.
