Statics
Area Moment of Inertia Converter
Convert between Area Moment of Inertia units.
Beams Fixed at Both Ends with Continuous and Point Loads: Load & Deflection Formulas
Bollard Forces
Friction, load and effort forces acting in ropes turned around bollards.
Cable Loads
Force and tension in cables with uniform loads.
Center Mass
Calculate position of center mass.
Center of Gravity
A body and the center of gravity.
Stability - the center of gravity vs. the center of buoyancy.
Earth Pressure Acting on Basement Walls
Calculate lateral earth pressure acting on basement walls.
Engineering Materials - Properties
Some typical properties of engineering materials like steel, plastics, ceramics and composites.
Equilibrant Force
The force required to keep a system of forces in equilibrium.
Fibre-reinforced Polymer Composites
Mechanical properties of fibers used to reinforce polymer composites.
Force
Hooke's Law
Hooke's law - force, elongation and spring constant.
Levers
Use levers to magnify forces.
Low-Frequency Vibrations Effects on Building Constructions
Effects of low-frequency vibrations on building constructions.
Mass Moment of Inertia
The Mass Moment of Inertia vs. mass of object, it's shape and relative point of rotation - the Radius of Gyration.
Mass vs. Weight
Modulus of Rigidity
Poisson's Ratios Metals
Screw Jack - Effort Force vs. Load
Screw jacks and effort forces.
Shafts Torsion
The torsion of solid or hollow shafts - Polar Moment of Inertia of Area.
Soil - Bearing Strength
Allowable loads on soil.
Stiffness
Stiffness is resistance to deflection.
Stress
Stress in Thick-Walled Cylinders or Tubes
Radial and tangential stress in thick-walled cylinders or tubes with closed ends - with internal and external pressure.
Stress in Thin-Walled Cylinders or Tubes
Hoop and longitudinal stress thin-walled tubes or cylinders.
Support Reactions - Equilibrium
Static equilibrium is achieved when the resultant force and resultant moment equals to zero.
Three-Hinged Arches - Continuous and Point Loads
Support reactions and bending moments.
Trusses
Common types of trusses.
Typical Floor Loads
Uniformly and concentrated floor loads
Vector Addition
Online vector calculator - add vectors with different magnitude and direction - like forces, velocities and more.
Wire Rope Slings
Beams and Columns
