Modulus of Rigidity
Modulus of Rigidity - G  - (Shear Modulus) is the coefficient of elasticity for a shearing force. It is defined as
  • "the ratio of shear stress to the displacement per unit sample length (shear strain)"
Modulus of Rigidity can be experimentally determined from the slope of a stress-strain curve created during tensile tests conducted on a sample of the material.
The definition of Modulus of Rigidity:
  • the ratio of shear stress to the displacement per unit sample length (shear strain)
Modulus of Rigidity of some Common Materials
Mechanics
Statics
Bulk Modulus and Fluid Elasticities
Introduction to - and definition of - Bulk Modulus Elasticity commonly used to characterize the compressibility of fluids.
Engineering Materials - Properties
Some typical properties of engineering materials like steel, plastics, ceramics and composites.
The Bulk Modulus - resistance to uniform compression - for some common metals and alloys.
Metals Strength vs. Temperature
The influence of temperature on the strength of metals.
Poisson's Ratio – Definition, Values for Materials, and Applications
Poisson's ratio, a key material property describing the relationship between axial and lateral strain in solid materials. Typical Poisson's ratio values for metals, polymers, ceramics, and more, along with practical applications in engineering and mechanics.
Poisson's Ratios Metals
Polymers - Physical Properties
Densities, tensile strength, elongation, Youngs modulus and Brinell hardness.
Rotating Shafts - Torque
Torsional moments acting on rotating shafts.
Section Modulus - Unit Converter
Convert between Elastic Section Modulus units.
Shafts Torsion
The torsion of solid or hollow shafts - Polar Moment of Inertia of Area.
Softwood and Hardwood - Structural Strength Classes
Strength classes, bending stress and mean density of hardwood and softwood
Square Hollow Structural Sections (HSS) – Sizes, Strength & Specifications
Steel Angles - Unequal Legs
Stiffness
Stiffness is resistance to deflection.
Trusses
Common types of trusses.
