Corrosion
Chemical Resistance of Thermoplastics
Chemical resistance of thermoplastics like ABS, CPVC, PP, PVC, PE, PB, PVDF and PEX piping materials to chemicals and products ranging beer, acryl acid, diesel oil and many more.
Copper Tubes - Corrosion Resistance to Chemicals
Copper tubes corrosion resistance to different products and chemicals.
CPVC - Chemical Resistance
Chemical resistance of CPVC - Chlorinated Poly (Vinyl Chloride) - to common chemicals and products.
Epoxy - Chemical Resistance
Chemical resistance of Epoxy to common products like Acetic acid, Alcohol, Diesel oil and more.
Glossary of Corrosion Related Terms
Commonly used terms related corrosion.
Metals in Seawater - Galvanic Series
Galvanic series of metals in seawater.
Pipes - Corrosion Protection
A corrosion protection tutorial for piping systems.
Piping Materials - Galvanic Corrosion
Connecting pipes of different materials may cause galvanic corrosion and serious damage.
Polyester - Chemical Resistance
Chemical resistance of Polyester to products like Acetic acid, Diesel oil and others.
PP Polypropylene - Chemical Resistance
Chemical resistance of Polypropylene - PP - to acids, bases, organic substances and solvents.
Stainless Steels - Corrosion Resistance
Corrosion resistanse of AISI stainless steels in various environments.
Stainless Steels - Identification Tests
Magnetic, spark, hardness and acid identification tests for austenitic, martensitic and ferritic stainless steels.
Steel Pipes - Corrosion due to Oxygen
The influence of oxygen concentration and temperature on the corrosion of steel pipes.
Types of Corrosion
Uniform, pitting, galvanic, crevice, concentration cell and graphitic types of corrosion.
Vinyl Ester - Chemical Resistance
Chemical resistance of Vinyl Ester to products as Acetone, Alcohol, Diesel oil and more.
