Viscosities
Calcium Chloride Water Solutions
Freezing point, density, specific heat and dynamic viscosity of Calcium Chloride Water coolants.
Carbon Dioxide (CO₂) Properties & Characteristics: Density, Thermal Data & More
Carbon Dioxide - Dynamic and Kinematic Viscosity vs. Temperature and Pressure
Online calculator, figures and table showing dynamic and kinematic viscosity of carbon dioxide, CO2, at varying temperature and pressure - Imperial and SI Units.
Centrifugal Pumps - Influence of Viscosity
Hydrodynamic losses through pumps depends on fluid viscosities.
Crude Oil Viscosity vs. Gravity
Viscosity at 20°C/68°F and 50°C/122°F for more than 120 crudes is shown as function of specific gravity@15°C/60°F.
Dry Air Thermodynamic and Physical Properties – Density, Specific Heat, Viscosity
THe essential thermodynamic properties of dry air like specific heat, ratio of specific heats, dynamic viscosity, thermal conductivity, Prandtl number, density and kinematic viscosity at temperatures ranging 175 - 1900 K.
Dynamic (Absolute) Viscosity - Converting Chart
Convert dynamic viscosity values between units like Poiseuille - Poise - centiPoise and more.
Engine & Gear Oil - Recommended Viscosity vs. Outside Temperature
Oil viscosity vs. temperature.
Ethane - Dynamic and Kinematic Viscosity
Online calculator, figures and tables showing dynamic and kinematic viscosity of ethane, C2H6, at varying temperature and pressure - Imperial and SI Units
Ethanol - Thermophysical properties
Chemical, physical and thermal properties of ethanol (also called alcohol or ethyl alcohol). Phase diagram included.
Food Products - Viscosities
Absolute (dynamic) viscosity for common food products.
Gases - Dynamic Viscosities
Absolute (dynamic) viscosities of some common gases.
Industrial Lubricants - Viscosities vs. ISO-VG Grade
ISO-VG viscosity grades for industrial lubricants.
Kinematic Viscosity - Unit Converter
Convert between Centistokes, Saybolt and Redwood seconds.
Liquids - Dynamic Viscosities
Absolute (dynamic) viscosity values for some common fluids.
Motor Oils - Dynamic Viscosities
Dynamic viscosities for motor oils SAE 10 to 50 for temperatures ranging 0-100 oC.
Nitrogen - Dynamic and Kinematic Viscosity vs. Temperature and Pressure
Online calculator, figures and tables showing dynamic and kinematic viscosity of nitrogen, N2, at varying temperature and pressure - Imperial and SI Units.
Oil Fuels - Viscosities vs. Temperatures
Viscosities of fuel oils vs. temperature.
Oil Viscosity Converter
Convert between commonly used oil viscosity units.
Seawater - Properties
Seawater properties like density, saturation pressure, specific heat, electrical conductivity and absolute viscosity.
Steam - Viscosity vs. Pressure
Absolute viscosity of steam at pressure ranging 1 - 10000 psia.
Sugar Water Solutions - Viscosities
Dynamic viscosities of sucrose water solutions vs. temperature.
Toluene - Thermophysical Properties
Chemical, physical and thermal properties of toluene, also called methylbenzene, toluol and phenylmethane. Phase diagram included.
Viscosity Converter: Convert Between Dynamic & Kinematic Viscosity
Water - Absolute (Dynamic) Viscosity vs. Temperature and Pressure
Absolute viscosity for water in centipoises for temperatures between 32 - 200oF.
Water - Dynamic and Kinematic Viscosity at Various Temperatures and Pressures
