Calcium Chloride Water Solutions
Freezing point, density, specific heat and dynamic viscosity of calcium chloride - water coolant:
Freezing Point
Calcium Chloride to Water Concentration (% by mass, weight) | Specific Gravity (at 60oF, 15.6oC) | Freezing Point | Boiling Point | ||
(oF) | (oC) | (oF) | (oC) | ||
40 | 1.416 | 61 | 16 | 247 | 119 |
30 | 1.298 | -52 | -47 | 231 | 111 |
20 | 1.189 | -4 | -20 | 220 | 104 |
10 | 1.090 | 20 | -6.7 | 215 | 102 |
Note the eutectic point at 29.92 % as indicated in the chart above.
Density
Specific Heat
Dynamic Viscosity
• Boiling Points of Fluids
• Densities
• Melting and Freezing Points
• Viscosities
Antifreeze - Ethylene Glycol Volume vs. Temperature Rating
Freeze protecting of cooling systems - temperature rating vs. required amount of antifreeze.
Ethanol Freeze Protected Water Solutions
Freezing temperature and flash points for ethanol based water solutions or brines.
Freeze Protection of Water based Heat Transfer Fluids
Comparing antifreezes used in water based heat transfer fluids or brines.
Isopropanol (2-Propanol) based Freeze Protected Water Solutions
Freezing and flash points of isopropanol (2-Propanol) based water solutions or brines.
Secondary Coolants - Properties
Comparing properties like specific gravity, freezing points and viscosity for secondary coolants like calcium chloride, sodium chloride, ethylene glycol and propylene glycol.
Sodium Chloride Water Solutions
Freezing point, density, specific heat and dynamic viscosity of Sodium Chloride and Water coolant.
