Fasteners
Bolt Torque Calculator: Loads & Preloads Data and Calculator
Calculate required bolt torque.
Drill Bits - Conversion Chart
Convert between drill bit dimensions - gauge numbers, inches and mm.
Fasteners - Type Chart
Wood screws, machine screws, sheet metal screws, self drilling SMS and more.
Improvised Torque Wrench
Metric Bolt Heads and Wrench Sizes
ANSI/SO, DIN and JIS bolts.
Metric Nuts - Proof Loads
Proof loads of metric nuts - coarse and fine threads.
Metric Threads - Clearance Holes and Tapping Drill Sizes
Recommended clearance holes and drill tap sizes.
Nails and Spikes - Metric Dimensions
Nails and spikes - commonly used metric sizes.
Nails and Spikes - U.S. Standard Dimensions
US common wire standard nail and spikes sizes and dimensions - Imperial Units.
Nails and Spikes - Withdrawal Force
Allowable withdrawal load for nail and spikes.
Screws - Metric vs. Inches
Metric versus Imperial equivalent screw dimensions.
Steel Bolts - ASTM Grades
Steel Bolts - SAE Grades
T-Slots and T-Nuts - Metric Sizes
Standard metric T-slots and T-nuts.
Threaded Bolts - Stress Area
Threaded bolts tensile stress area.
Threaded Rods - Loads in Imperial Units
Weight rating of threaded hanger rods.
Threaded Rods - Proof Loads - Metric Units
Proof load capacities of metric threaded steel rods.
Torque Specifications for Metric Bolts: Maximum Values & Tables
U.S. and Metric Fasteners - Thread Sizes
Printable fastener chart.
U.S. Bolts - Head and Wrench Sizes
Hex Bolt, Lag Bolt, Square Bolt and Heavy Hex Bolt.
U.S. Bolts - Tightening Torques
Recommended bolt torques.
U.S. Bolts: Tensile Strength & Proof Load Specifications
Unified Thread Standards: UNC & UNF Size Charts & Specifications
US Hex Bolts - Inches
ANSI/ASME B18.2.1 Dimensions of Hex Bolts - Imperial units.
US Hex Bolts - Metric
US Machine Screws - Dimensions
Machine screw diameters.
US Wood Screws - Nominal Sizes
Wood screws - nominal sizes vs. diameters.
US Wood Screws - Pilot Holes
Hard wood and soft wood pilot holes, shank clearance holes and countersink diameters.
Whitworth Bolt Torques
Torque specifications Whitworth bolts.
Wood Screws - Withdrawal Force
Allowable withdrawal load force.
Wrench Size Conversion Chart – Metric (mm) to SAE (Inches)
Convert between metric and SAE (inch) wrench sizes with this comprehensive comparison chart. Find the closest equivalent sizes for your tools, whether working with US standard (SAE) or metric fasteners.
