US Wood Screws - Pilot Holes
Approximate hole size for wood screws used in hard wood and soft wood:
Nominal Size
no.
Nominal Shank Diameter
(in)
Actual Shank Diameter
(in)
Twist Drill Size
Pilot HolesShank Clearance Holes80o Countersink Diameter
Hard WoodSoft Wood
Inch
No.Inches
No.Inch
No.Actual Head Diameter
(in)
Diameter
(in)
0 0.060 0.064 3/64 58 1/32 69 1/16 52 0.119 1/8
1 0.073 0.077 3/64 55 1/32 65 5/64 47 0.146 3/16
2 0.086 0.090 1/16 53 3/64 59 3/32 42 0.172 3/16
3 0.099 0.103 1/16 51 3/64 56 7/64 37 0.199 1/4
4 0.112 0.116 5/64 48 3/64 55 7/64 32 0.225 1/4
5 0.125 0.129 5/64 44 1/16 53 1/8 30 0.252 1/4
6 0.138 0.142 3/32 42 1/16 52 9/64 27 0.279 3/8
7 0.151 0.155 3/32 38 1/16 50 5/32 22 0.305 3/8
8 0.164 0.168 7/64 35 5/64 48 11/64 18 0.332 3/8
9 0.177 0.181 1/8 32 5/64 46 3/16 14 0.358 3/8
10 0.190 0.194 1/8 30 3/32 44 3/16 10 0.385 1/2
11 0.203 0.207 1/8 29 3/32 43 13/64 4 0.412 1/2
12 0.216 0.220 9/64 27 3/32 39 7/32 2 0.438 1/2
14 0.242 0.246 5/32 20 7/64 34 1/4 D 0.507 1/2
16 0.268 0.272 3/16 16 1/8 31 17/64 I 0.544 5/8
18 0.294 0.298 3/16 10 9/64 29 19/64 N 0.635 5/8
20 0.320 0.324 7/32 3 5/32 26 21/64 P 0.650 3/4
24 0.372 0.376 1/4 D 11/64 18 3/8 V 0.762 3/4
Fasteners
Miscellaneous
Drill Bits - Conversion Chart
Convert between drill bit dimensions - gauge numbers, inches and mm.
Hardwood and Softwoods - Recommended Drill Bit Speeds
Hardwood and softwood drill speed chart.
Hardwood Lumber - Dimensions
Sizing of hardwood lumber.
Lumber - Surface Finishing
Lumber and surface finishing abbreviations.
Lumber Weights: Green, Kiln-Dried & Pressure-Treated Wood
Metric Threads - Clearance Holes and Tapping Drill Sizes
Recommended clearance holes and drill tap sizes.
Nails and Spikes - Withdrawal Force
Allowable withdrawal load for nail and spikes.
Sandpapers - Grit Sizes
Grit sizes ranging 12 - 600.
Screws - Metric vs. Inches
Metric versus Imperial equivalent screw dimensions.
US Machine Screws - Dimensions
Machine screw diameters.
US Wood Screws - Nominal Sizes
Wood screws - nominal sizes vs. diameters.
Wood Headers - Max. Supported Weight
Wood Screws - Withdrawal Force
Allowable withdrawal load force.
