Temperature Measurements
Dust Explosions - Substances, Critical Temperatures and Concentrations
Critical temperatures and concentration parameters for substances like coal, zinc, uranium and more.
Fixed Temperature Points
Temperature points that can be used as a reference for calibration
IP - Ingress Protection Ratings
IP - Ingress Protection rating is used to specify the environmental protection - or electrical enclosure - of electrical equipment.
ISA process instrumentation codes - and combinations.
Pt100 - Platinum Resistance Thermometer
Pt100 electrical resistance temperature sensor - ranging -220 to 750 degrees Celsius.
RTD Resistance Temperature Sensor
Thermal resistive sensor - a basic introduction.
Selecting Temperature Sensors
RTD vs. thermocouples temperature sensors.
Temperature Sensors - Comparing Types
Comparing advantages and disadvantages of thermocouples, RTDs and thermistors temperature sensors.
Thermocouple Temperature Measurements
An introduction to the frequently used temperature transducers - the thermocouple.
Thermocouples
Thermocouples - types, principles and temperature ranges.
