Temperature Sensors - Comparing Types
AttributeThermocoupleRTDThermistor
Cost Low High Low
Temperature Range Very wide
-350 oF
+3200 oF
Wide
-400 oF
+1200 oF
Short to medium
-100 oF
+500 oF
Interchange ability Good Excellent Poor to fair
Long-term Stability Poor to fair Good Poor
Accuracy Medium High Medium
Repeatability Poor to fair Excellent Fair to good
Sensitivity (output) Low Medium Very high
Response Medium to fast Medium Medium to fast
Linearity Fair Good Poor
Self Heating No Very low to low High
Point (end) Sensitive Excellent Fair Good
Lead Effect High Medium Low
Size/Packaging Small to large Medium to small Small to medium
  • A thermocouple has two dissimilar conductors forming electrical junctions at differing temperatures. The thermocouple produces a temperature-dependent voltage as a result of the thermoelectric effect and can be interpreted as a temperature measurement.
  • A RTD - Resistance Thermometer Detector - are made of a length of fine wire wrapped around a ceramic or glass core. The RTD wire is of pure material - typically platinum, nickel, or copper - with an accurate resistance/temperature relationship. The electrical resistance provides an indication of the temperature.
  • A thermistor is a type of resistor made of ceramic or polymer materials. The resistance is - like the RTD - dependent on temperature. A PTC (Positive Temperature Coefficient) conduct better at lower temperatures. A NTC (Negative Temperature Coefficient) conduct better at higher temperatures.
Process Control Systems
Instrumentation, design and documentation of process control systems.
Temperature Measurements
Fixed Temperature Points
Temperature points that can be used as a reference for calibration
Pt100 - Platinum Resistance Thermometer
Pt100 electrical resistance temperature sensor - ranging -220 to 750 degrees Celsius.
Resistivity and Conductivity - Temperature Coefficients Common Materials
Resistivity, conductivity and temperature coefficients for common materials like silver, gold, platinum, iron and more..
RTD Resistance Temperature Sensor
Thermal resistive sensor - a basic introduction.
Thermocouples
Thermocouples - types, principles and temperature ranges.
