Fasteners - Type Chart
Fastener Categories
  • Wood Screws, Machine Screws, Sheet Metal Screws, Self Drilling SMS, Hex Bolts, Carriage Bolts, Lag Bolts, Set Screws, Socket Screws, Eye Bolts, Eye Lags, U-Bolts, J-Bolts, Hanger Bolts
Head Styles
  • Flat, Oval, Pan, Truss, Round, Hex, Hex Washer, Slotted Hex Washer, Socket Cap, Button
Drive Types
  • Phillips and Frearson, Slotted, Combination, Socket, Hex, Allen
Nut Types
  • Hex, Nylon Insert Lock, Jam, Nylon Insert Jam Lock, Wing, Cap, Acorn, Flange, Tee, Square, Prevailing Torque Lock, K-Lock or Keep, Coupling
Washer Types
  • Flat, Fender, Finishing, Split Lock, External Toot Lock, Internal Toot Lock, Square, Dock, Ogee
http://www.boltdepot.com/fastener-information/Printable-Tools/Type-Chart.pdf
Fasteners
Miscellaneous
Drill Bits - Conversion Chart
Convert between drill bit dimensions - gauge numbers, inches and mm.
Glue-Laminated Timber - Dimensions
Common sizing of glue-laminated timber.
