Isopropanol (2-Propanol) based Freeze Protected Water Solutions
Isopropyl alcohol is also commonly used as a cleaner and solvent in industry. It is also used as a gasoline additive for dissolving water or ice in fuel lines.
Freezing Point of Isopropanol (2-Propanol) based Water Solutions
Isopropanol (2-Propanol) based Freeze Protected Water Solutions - Freezing Points
Isopropanol Concentration
(% by volume)
0102030405060708090100
Freezing Points oF 32 25 20 5 0 -5 -10 -20 -35 -70 -130
oC 0 -4 -7 -15 -18 -21 -23 -29 -37 -57 -90
Flash Points of Isopropanol (2-Propanol) based Water Solutions
The flash point of a chemical is the lowest temperature where it will evaporate enough fluid to form a combustible concentration of gas. The flash point is an indication of how easy a chemical may burn.
Isopropanol (2-Propanol) based Freeze Protected Water Solutions - Flash Points
(% by volume)
Flash Points oF - 105 85 75 70 65 65 65 65 65 53
oC - 41 29 24 21 18 18 18 18 18 12
Alternatives to Isopropanol (2-Propanol) based Water Solutions
Material Properties
Melting and Freezing Points
Antifreeze - Ethylene Glycol Volume vs. Temperature Rating
Freeze protecting of cooling systems - temperature rating vs. required amount of antifreeze.
Calcium Chloride Water Solutions
Freezing point, density, specific heat and dynamic viscosity of Calcium Chloride Water coolants.
Ethanol Freeze Protected Water Solutions
Freezing temperature and flash points for ethanol based water solutions or brines.
Freeze Protection of Water based Heat Transfer Fluids
Comparing antifreezes used in water based heat transfer fluids or brines.
Freezing Mixtures and Cooling Agents
Freezing mixtures, cooling agents and freezing points.
Glycerine - Boiling and Freezing Points
Boiling and freezing points of glycerine aqueous solutions.
Hazard vs. Flash Points
The flash point of a chemical indicates how easy it may ignite and burn.
Methanol Freeze Protected Heat Transfer Liquids
Freezing and flash points for methanol or methyl based heat-transfer fluids or brines.
Secondary Coolants - Properties
Comparing properties like specific gravity, freezing points and viscosity for secondary coolants like calcium chloride, sodium chloride, ethylene glycol and propylene glycol.
