Isopropanol (2-Propanol) based Freeze Protected Water Solutions
Freezing and flash points of isopropanol (2-Propanol) based water solutions or brines.
Isopropyl alcohol is also commonly used as a cleaner and solvent in industry. It is also used as a gasoline additive for dissolving water or ice in fuel lines.
Freezing Point of Isopropanol (2-Propanol) based Water Solutions
Isopropanol (2-Propanol) based Freeze Protected Water Solutions - Freezing Points
Isopropanol Concentration
(% by volume)
0102030405060708090100
Freezing Points oF 32 25 20 5 0 -5 -10 -20 -35 -70 -130
oC 0 -4 -7 -15 -18 -21 -23 -29 -37 -57 -90
Flash Points of Isopropanol (2-Propanol) based Water Solutions
The flash point of a chemical is the lowest temperature where it will evaporate enough fluid to form a combustible concentration of gas. The flash point is an indication of how easy a chemical may burn.
Isopropanol (2-Propanol) based Freeze Protected Water Solutions - Flash Points
(% by volume)
Flash Points oF - 105 85 75 70 65 65 65 65 65 53
oC - 41 29 24 21 18 18 18 18 18 12
Alternatives to Isopropanol (2-Propanol) based Water Solutions
