Water - Absolute (Dynamic) Viscosity vs. Temperature and Pressure
Absolute or dynamic viscosity is used to calculate Reynolds Number to determine if a fluid flow is laminar, transient or turbulent.
- Reynold's Number - a definition
The absolute or dynamic viscosity of water depends on the temperature as indicated below:
Temperature | Absolute - Dynamic - Viscosity (cP) | |
(oF) | (oC) | |
32 | 0 | 1.794 |
40 | 4.4 | 1.546 |
50 | 10.0 | 1.310 |
60 | 15.6 | 1.129 |
70 | 21.1 | 0.982 |
80 | 26.7 | 0.862 |
90 | 32.2 | 0.764 |
100 | 37.8 | 0.682 |
120 | 48.9 | 0.559 |
140 | 60.0 | 0.470 |
160 | 71.1 | 0.401 |
180 | 82.2 | 0.347 |
200 | 93.3 | 0.305 |
- 1 cP = 0.01 poise = 0.01 gram per cm second = 0.001 Pascal second = 1 milliPascal second = 0.001 N.s/m2
- Convert viscosity
Water - Relative Viscosity vs. Higher Pressure and Temperature
• Viscosities
Cooling Water - Pipe Lines
Sizing cooling water pipe lines - maximum allowable flow, velocity and pressure drops.
Dynamic (Absolute) Viscosity - Converting Chart
Convert dynamic viscosity values between units like Poiseuille - Poise - centiPoise and more.
Laminar vs. Turbulent Flow - Reynolds Number Explained with Calculator
Laminar, Transitional and Turbulent Flow
Heat transfer, pressure and head loss in a fluid varies with laminar, transitional or turbulent flow.
Liquids - Dynamic Viscosities
Absolute (dynamic) viscosity values for some common fluids.
Seawater - Properties
Seawater properties like density, saturation pressure, specific heat, electrical conductivity and absolute viscosity.
Secondary Coolants - Properties
Comparing properties like specific gravity, freezing points and viscosity for secondary coolants like calcium chloride, sodium chloride, ethylene glycol and propylene glycol.
Steam - Viscosity vs. Pressure
Absolute viscosity of steam at pressure ranging 1 - 10000 psia.
Viscosity Converter: Convert Between Dynamic & Kinematic Viscosity
Water - Dynamic and Kinematic Viscosity at Various Temperatures and Pressures
Water - Properties vs. Temperature and Pressure
Liquid water properties at temperatures between melting point and boiling point and pressures of 14.7 psia, 1000 psia and 10000 psia (1 atm, 68.1atm and 681 atm).
Water Flow in Tubes - Reynolds Number
Reynolds number for clean cold water flow.
