Dynamic (Absolute) Viscosity Units Online Calculator
The calculator below can be used to convert between common absolute or dynamic viscosity units:
A Dynamic (Absolute) Viscosity Units Converting Table
The table below can be used to convert between common dynamic or absolute viscosity units.
Dynamic (Absolute) Viscosity Units Converter
Convert fromMultiply by
Convert to
Poiseuille
(Pa s)
Poise
(dyne s/cm2)
(g/cm s)
centiPoisekg/m hkgf s/m2
Poiseuille
(Pa s)
1 10 103 3.63×103 0.102
Poise
(dyne s/cm2)
(g/cm s)
0.1 1 100 360 0.0102
centiPoise 0.001 0.01 1 3.6 0.00012
kg/m h 2.78×10-4 0.00278 0.278 1 2.83×10-5
kgf s/m2 9.81 98.1 9.81×103 3.53×104 1
lbf s/inch2(Reyns)
6.89×103 6.89×104 6.89×106 2.48×107 703
lbf s/ft2 47.9 479 4.79×104 1.72×105 0.0488
lbf h/ft2 1.72×105 1.72×106 1.72×108 6.21×108 1.76×104
lb/ft s 1.49 14.9 1.49×103 5.36×103 0.152
lb/ft h 4.13×10-4 0.00413 0.413 1.49 4.22×10-5
Convert to
lbf s/inch2(Reyns)
lbf s/ft2lbf h/ft2lb/ft slb/ft h
Poiseuille
(Pa s)
1.45×10-4 0.0209 5.8×10-6 0.672 2.42×103
Poise
(dyne s/cm2
g/cm s)
1.45×10-5 0.00209 5.8×10-7 0.0672 242
centiPoise 1.45×10-7 2.09×10-5 5.8×10-9 0.000672 2.42
kg/m h 4.03×10-8 5.8×10-6 1.61×10-9 0.000187 0.672
kgf s/m2 0.00142 20.5 5.69×10-5 6.59 2.37×104
lbf s/inch2 1 144 0.04 4.63×103 1.67×107
lbf s/ft2 0.00694 1 0.000278 32.2 1.16×105
lbf h/ft2 25 3.6×103 1 1.16×105 4.17×108
lb/ft s 0.000216 0.0311 8.63×10-6 1 3.6×103
lb/ft h 6 10-8 8.633×10-6 2.4×10-9 0.000278 1
Download and print Dynamic Viscosity Unit Converter chart
Common Dynamic or Absolute Viscosity Units
  • 1 Pascal second (Poiseuille) =  1000 Centipoise
  • 1 Pascal second (Poiseuille) = 10 Dyne second / centimetre2
  • 1 Pascal second (Poiseuille) = 0.0102 Gram force seconds / centimetre2
  • 1 Pascal second (Poiseuille) = 10 Gram / centimetre second
  • 1 Pascal second (Poiseuille) = 0.102 Kilogram force seconds / metre2
  • 1 Pascal second (Poiseuille) = 3600 Kilogram / metre hour
  • 1 Pascal second (Poiseuille) = 1 Kilogram / metre second
  • 1 Pascal second (Poiseuille) = 107 Micropoise
  • 1 Pascal second (Poiseuille) = 1 Newton Second / metre2
  • 1 Pascal second (Poiseuille) = 10 Poise
  • 1 Pascal second (Poiseuille) = 0.0209 Pound force seconds / ft2
  • 1 Pascal second (Poiseuille) = 0.000145 Pound force seconds / in2
  • 1 Pascal second (Poiseuille) = 2419.1 Pound / foot hour
  • 1 Pascal second (Poiseuille) = 0.672 Pound / foot second
  • 1 Pascal second (Poiseuille) = 0.056 Pound / inch second
  • 1 Pascal second (Poiseuille) = 0.672 Poundal seconds / ft2
  • 1 Pascal second (Poiseuille) = 0.000145 Reyn
  • 1 Pascal second (Poiseuille) = 0.0209 Slugs / foot second
Fluid Mechanics
Viscosities
Crude Oil Viscosity vs. Gravity
Viscosity at 20°C/68°F and 50°C/122°F for more than 120 crudes is shown as function of specific gravity@15°C/60°F.
Dynamic (Absolute) Viscosity - Converting Chart
Convert dynamic viscosity values between units like Poiseuille - Poise - centiPoise and more.
Engine & Gear Oil - Recommended Viscosity vs. Outside Temperature
Oil viscosity vs. temperature.
Industrial Lubricants - Viscosities vs. ISO-VG Grade
ISO-VG viscosity grades for industrial lubricants.
Liquids - Dynamic Viscosities
Absolute (dynamic) viscosity values for some common fluids.
Motor Oils - Dynamic Viscosities
Dynamic viscosities for motor oils SAE 10 to 50 for temperatures ranging 0-100 oC.
Poiseuille's Formula
Calculate the volume flow discharged through a smooth-walled circular pipe.
Viscosities and densities of SAE Grade oils.
Steam - Viscosity vs. Pressure
Absolute viscosity of steam at pressure ranging 1 - 10000 psia.
Steel Pipes - Viscous Liquid Flow and Friction Loss
Friction loss in schedule 40 steel pipe with viscous liquids - viscosities ranging from water to oil.
Unit Factor Method
Viscosity Converter: Convert Between Dynamic & Kinematic Viscosity
Water - Absolute (Dynamic) Viscosity vs. Temperature and Pressure
Absolute viscosity for water in centipoises for temperatures between 32 - 200oF.
Water - Dynamic and Kinematic Viscosity at Various Temperatures and Pressures
