Crude Oil Viscosity vs. Gravity
The figure is based on information from more than 120 crude oil assays from BP, ExxonMobile and Statoil (2008 - 2017). The crudes are produced all over the world.
See also Crude metal (Ni, V) content as function of gravity .
• Densities
• Viscosities
API Gravity: Definition, Calculation, and Converter
API expresses the gravity or density of liquid petroleum products. Online API to Specific Gravity calculator.
Centrifugal Pumps - Influence of Viscosity
Hydrodynamic losses through pumps depends on fluid viscosities.
Crude Oil Metal (Ni, V) Content vs. Gravity
Content of nickel and vanadium in more than 120 crudes as function of specific gravity@15°C/60°F.
Crude Oil Properties - Standard test methods (ASTM and others)
An overview of common test methods and typical ranges of variation of petroleum quality parameters. What, why and how do the different test?
Density Converter
Dynamic (Absolute) Viscosity - Converting Chart
Convert dynamic viscosity values between units like Poiseuille - Poise - centiPoise and more.
Kinematic Viscosity - Unit Converter
Convert between Centistokes, Saybolt and Redwood seconds.
Liquids - Dynamic Viscosities
Absolute (dynamic) viscosity values for some common fluids.
Liquids - Specific Gravities
Specific gravities for common fluids like acetone, alcohol, turpentine, oil and more.
Oil Viscosity Converter
Convert between commonly used oil viscosity units.
Petroleum Products - Standard Test Methods (ASTM and others) and Specifications
An overview of common test methods and specifications of petroleum fuels. What, why and how do the different test?
Yield Structure of Crude Oils with Increasing Density of Crude
Yields of different crude oil distillation cuts are plotted as function of whole crude specific gravity. Fractions based on European and North American markets, and the typical differences in crude oil fractionation in the two markets are also shown.
