Centrifugal Pumps - Influence of Viscosity
When a more viscous fluid is handled by a centrifugal pump
  • brake horsepower requirement increases
  • the head generated is reduced
  • capacity is reduced
  • efficiency of pump is reduced and the Best Efficiency Point - BEP - is moved
The head, flow and capacity with fluids with other viscosities than used in the original documentation can be modified with coefficients.
Flow
qv = cq q                                (1)
qv = flow compensated for viscosity (m3/h, gpm)
cq = viscosity flow coefficient
q = original flow according pump curve (m3/h, gpm)
Head
hv = ch h                               (2)
hv = head compensated for viscosity (m, ft)
ch = viscosity head coefficient
h = original head according pump curve (m, ft)
Efficiency
μv = cμ μ                             (3)
μv = effciency compensated for viscosity
cμ = viscosity efficiency coefficient
μ = original efficiency according pump curve
Power - SI units
Pv = qv hv ρv g / (3.6×106  μv)                            (4)
Pv = power compensated for viscosity (kW)
ρv = density of viscous fluid (kg/m3)
Power - Imperial units
Pv = qv hv SG / (3960 μv)                              (5)
Pv = power compensated for viscosity (bhp)
SG = specific gravity of viscous fluid
Pumps
Viscosities
BEP - the Best Efficiency Point of a Pump
BEP is where the pump is most efficient.
Centrifugal Pumps - Minimum Flow
Minimum continuous flow to prevent flashing in centrifugal pumps.
Centrifugal Pumps - Shut-Off Head
Centrifugal pumps and maximum shut-off head.
Crude Oil Viscosity vs. Gravity
Viscosity at 20°C/68°F and 50°C/122°F for more than 120 crudes is shown as function of specific gravity@15°C/60°F.
Efficiency in Pumps or Fans
The overall pump and fan efficiency is the ratio power gained by the fluid to the shaft power supplied.
Food Products - Viscosities
Absolute (dynamic) viscosity for common food products.
Industrial Lubricants - Viscosities vs. ISO-VG Grade
ISO-VG viscosity grades for industrial lubricants.
Liquids - Specific Gravities
Specific gravities of liquids like alcohol, oils, benzene, water and many more.
Power Gained by Fluid from Pump or Fan
Calculate the power gained by fluid from an operating pump or fan.
Viscosities and densities of SAE Grade oils.
Steel Pipes - Viscous Liquid Flow and Friction Loss
Friction loss in schedule 40 steel pipe with viscous liquids - viscosities ranging from water to oil.
System Curve and Pump Performance Curve
Utilize the system curve and the pump performance curve to select the proper pump for a particular application.
Viscosity Converter: Convert Between Dynamic & Kinematic Viscosity
