Power Gained by Fluid from Pump or Fan
The power gained by the fluid from a pump or fan can be expressed as:
P = m w                          (1)
P = power (W)
m = mass flow rate (kg/s)
w = specific work (Nm/kg, J/kg)
Specific Work
Specific work - w - can be expressed:
w = g h                           (2)
h = head (m)
Mass Flow Rate
Mass flow rate - m - can be expressed:
m = ρ Q                          (3)
ρ = density (kg/m3)
Q = volume flow rate (m3/s)
Combining (1), (2) and (3) the power gained by the fluid from a pump or fan can be expressed as:
P = ρ Q g h                           (4)
With specific weight expressed as:
γ = ρ g                            (5)
γ = specific weight (N/m3)
equation (4) can be modified so the power gained by the fluid from a pump or fan can be expressed as:
P = γ Q h                           (6)
Since head can be expressed as
h = (p2 - p1) / γ                          (7)
P = Q (p2 - p1)                          (8)
Example - Head Rise of a Inline Pump
An inline water pump works between measured pressure 1 bar (1×105 N/m2) and 10 bar (10×105 N/m2). Density of water is 1000 kg/m3. The volume flow is measured to 1×10-3 m3/s.
The actual water head (water column) can be calculated using (7):
h = (p2 - p1) / γ
    = (p2 - p1) / ρ g
    = ((10×105 N/m2) - (1×105 N/m2)) / (1,000 kg/m3) (9.81 m/s2)
    = 91.7 m - water column
The power gained by the fluid can be calculated using equation (4):
P = ρ Q g h
    = (1,000 kg/m3) (1×10-3 m3/s) (9.81 m/s2) (91.7 m)
    = 899.6 kgm2/s3 (W)
    = 0.9 kW
Pumps
Centrifugal Pumps - Influence of Viscosity
Hydrodynamic losses through pumps depends on fluid viscosities.
Centrifugal Pumps - Minimum Flow
Minimum continuous flow to prevent flashing in centrifugal pumps.
Efficiency in Pumps or Fans
The overall pump and fan efficiency is the ratio power gained by the fluid to the shaft power supplied.
Required power to pump water.
Power
