Centrifugal Pumps - Shut-Off Head
The maximum "shut-off" head for a centrifugal pump can be estimated as
hs = (d n / 1840)2 (1)
h = head (feet)
d = outside diameter impeller (inches)
n = wheel velocity - revolution per minute - (rpm)
• Pumps
Affinity Laws for Pumps: Principles, Formulas & Calculator
Turbo machines affinity laws can be used to calculate volume capacity, head or power consumption in centrifugal pumps when changing speed or wheel diameters.
Centrifugal Pump Standards
International centrifugal pump design and dimension standards.
Centrifugal Pumps
Centrifugal Pumps - Influence of Viscosity
Hydrodynamic losses through pumps depends on fluid viscosities.
Centrifugal Pumps - Minimum Flow
Minimum continuous flow to prevent flashing in centrifugal pumps.
Centrifugal Pumps - Speed Torque Curve
The characteristic speed torque curves for centrifugal pumps.
