Typical Floor Loads
Typical uniformly and concentrated floor loads are indicated below.
Typical Floor Loads
Type of ApplicationConcentrated Load
(kN)
Uniformly Distributed Load
(kN/m2)
Bedroom, dwelling 1.8 1.5
Bedroom, hotel 1.8 2.0
Bathroom 1.8 2.0
Balcony, dwelling 1.4 1.5
Balcony, hotel or guest house 1.5 kN/m at outer edge 3.0
Communal area 1.4 1.5
Factory, general 4.5 5.0
Kitchen, communal 4.5 3.0
Laboratory 4.5 3.0
Laundry 4.5 3.0
Library 4.5 4.0
Office 2.7 2.5
WC 1.8 2.0
Warehouse, general storage 1.8 2.0
Work area, general 2.7 2.5
Workshop 4.5 5.0
How to Calculate Load in kN?
If you have the mass in kg - the load in kN can be calculated as
F = m g / 1000                 (1)
F = load (N)
m = mass (kg)
g = gravitational acceleration (9.81 m/s2)
Example - Calculate the Load from a 800 kg Pallet
The load from a pallet with mass 800 kg can be calculated as
F = (800 kg) (9.81 m/s2) / 1000
  = 7.8 kN
Statics
Beams Fixed at Both Ends with Continuous and Point Loads: Load & Deflection Formulas
Building Foundations - Loads
Typical loads on building foundations.
Concrete Slabs - Load Capacities
Load capacity of simply supported concrete slabs.
Floor Joist Capacities
Floors - Live Loads
Horizontal Roof Rafters - Maximum Spans
Douglas Fir in horizontal roof rafters and maximum spans.
Maximum Floor Joist Span
No. 1 and No. 2 Grade of Douglas fir and maximum span floor joists - imperial units
W Steel Beams - Allowable Uniform Loads
Allowable uniform loads.
