Insulated Copper Tubes - Heat Loss
The heat loss from insulated copper pipes or tubes to surrounding air are indicated below. The heat loss is based on temperature difference 55 oC (99 oF) with insulation thickness 25 mm (1 inch) and conductivity coefficient k = 0.043 W/m oC (0.3 Btu in/ft2hr oF).
Nominal boreHeat Loss
(mm)(inches)(W/m)(Btu/hr ft)
22 3/4 8 8
28 1 10 10
42 1 1/2 11.5 12
54 2 14.5 15
67 2 1/2 16 17
76 3 19 20
  • 1 W = 3.4 Btu/hr
  • 1 ft (foot) = 0.3048 m
Download and print Insulated Copper Tubes Heat Loss Chart
Heat Loss and Insulation
Insulation
Piping Systems
Water Systems
ASTM B88M - Seamless Copper Water Tubes - Metric Dimensions
Water and gas copper tubes according ASTM B88M - type K, L and M - metric units.
BS 2871 Copper Tubes Table X, Y and Z - Working Pressures vs. Size
Copper Tubes - Heat Carrying Capacities
Hot water heat carrying capacities in copper tubes type L.
Copper Tubes - Heat Losses
Heat loss from uninsulated copper tubes vs. temperature differences between tube and air.
Insulation Materials - Operating Temperature Limits
Temperature limits for commonly used insulation materials.
Pipes - Insulated Heat Loss Diagrams
Heat loss (W/m) from 1/2 to 6 inches insulated pipesĀ - ranging insulation thickness 10 to 80 mm and temperature differences 20 to 180 degC.
Heat loss (W/ft) diagrams for 1/2 to 6 inches insulated pipesĀ - ranging insulation thickness 0.5 to 4 inches and temperature differences 50 to 350 degF.
Pipes and Cylinders - Conductive Heat Loss
Conductive heat losses through cylinder or pipe walls.
Steam Tracing Pipe Lines
Steam tracing of pipe lines can be done to maintain appropriate product temperatures.
