BS 2871 Copper Tubes Table X, Y and Z - Working Pressures vs. Size
The copper used in the manufacture of tubes is phosphorus deoxidized copper Cu-DHP defined by British Standard BS. 6017: 1981. This also corresponds to the ISO denomination Cu-DHP.
The minimum copper content is 99.85% and the residual phosphorus content is between 0.013 and 0.050%. This deoxidized copper is not affected by reducing atmospheres and consequently is well suited to welding and brazing. The density of copper is 8.9 g/cm3. its melting point is 1083 oC and its coefficient of linear expansion is 16.8×10-6 per oC (ranging 20 oC - 100 oC).
Note! -  this standard is replaced with EN 1057 - Copper tubes for water and gas in sanitary and heating applications
For full table with Table Z - rotate the screen!
Nom. Diameter
(mm)
Outside Diameter
(mm)
Table X
Half hard light gauge tube
Table Y
Half hard an annealed tube
Table Z
Hard drawn thin wall tube
Thickness
(mm)
Maximum Working Pressure
(N/mm2)
Thickness
(mm)
(N/mm2)
Thickness
(mm)
(N/mm2)
6 6 0.6 13.3 0.8 14.4 0.5 11.3
8 8 0.6 9.7 0.8 10.5 0.5 9.8
10 10 0.6 7.7 0.8 8.2 0.5 7.8
12 12 0.6 6.3 0.8 6.7 0.5 6.4
15 15 0.7 5.8 1 6.7 0.5 5
18 18 0.8 5.6 1 5.5 0.6 5
22 22 0.9 5.1 1.2 5.7 0.6 4.1
28 28 0.9 4 1.2 4.2 0.6 3.2
35 35 1.2 4.2 1.5 4.1 0.7 3
42 42 1.2 3.5 1.5 3.4 0.8 2.8
54 54 1.2 2.7 2 3.6 0.9 2.5
67 67 1.2 2 2 2.8 1 2
76.1 76.2 1.5 2.4 2 2.5 1.2 1.9
108 108.1 1.5 1.7 2.5 2.2 1.2 1.7
133 133.4 1.5 1.4 1.5 1.6
159 159.4 2 1.5 1.5 1.5
  • 1 N/mm2 = 106 Pa = 1 MPa = 10 bar = 1.020×105 kp/m2 = 102.0 m H2O = 9.869 atm = 145.0 psi (lbf/in2)
Pressure Ratings of Pipes and Fittings
ASTM B280 Copper Tube for Air Conditioning and Refrigeration (ACR) - Dimensions and Working Pressures
Standard specifications for seamless copper tube used in Air Conditioning and Refrigeration Field Services.
ASTM B302 - Threadless Copper Pipes - Dimensions
ASTM B306 Copper Tubes for Drain, Waste and Vent - Dimensions and Working Pressures
ASTM B42 - Seamless Copper Pipes - Dimensions
ASTM B43 - Seamless Red Brass Pipes - Dimensions
Standard sizes specification for seamless red brass pipes.
ASTM B837 - Seamless Copper Tubes for Natural Gas and Liquified Petroleum - Dimensions
ASTM B88 - Seamless Copper Water Tubes - Dimensions
ASTM B88M - Seamless Copper Water Tubes - Metric Dimensions
Water and gas copper tubes according ASTM B88M - type K, L and M - metric units.
BSi - Pipe, Tube and Fittings Standards and Specifications
British standards and specifications for pipe, tube and fittings.
Copper - Density, Specific Heat and Thermal Conductivity vs. Temperature
Density, specific heat and thermal conductivity of copper vs. temperature
Copper and Copper Alloy Pipes - Temperature Ranges
Bending copper pipe and tube temperatures.
Copper Tubes - Corrosion Resistance to Chemicals
Copper tubes corrosion resistance to different products and chemicals.
Copper Tubes - Equivalent Length Pressure Loss in Fittings and Valves
Copper tube fittings and equivalent lengths - in feets of straight tube.
Copper Tubes - Expansion Loop Capacity
Capacity of copper tubes expansion loops.
Copper Tubes - Heat Carrying Capacities
Hot water heat carrying capacities in copper tubes type L.
Copper Tubes - Heat Losses
Heat loss from uninsulated copper tubes vs. temperature differences between tube and air.
Copper Tubes - Maximum Water Velocities
Water velocity in a copper tube should not exceed certain limits to avoid erosion.
Copper Tubes - Pressure Loss vs. Water Flow
Water flow and pressure loss (psi/ft) due to friction in copper tubes ASTM B88 Types K, L and M.
Copper Tubes - Uninsulated Heat Losses
Heat loss from uninsulated copper pipes - dimensions ranging 1/2 - 4 inches.
Copper Tubes Supports
Maximum space between supports aand clips for copper tubes.
Copper Tubes Type K - Dimensions and Physical Characteristics
Physical characteristics of copper tubes ASTM B 88 type K.
Copper Tubes Type K, L and M - Working Pressures vs. Size
CTS - Copper Tube Sizes - Dimensions used in Plumbing
Copper tube sizes used in plumbing.
EN 1057 Copper Tubes for Water and Gas in Sanitary and Heating Applications - Dimensions
Dimensions of EN 1057 Copper and copper alloys - Seamless, round copper tubes for water and gas in sanitary and heating applications.
EN 12449 - Copper and Copper Alloys - Seamless, Round Tubes for General Purposes - Dimensions
Dimensions of copper tubes according EN 12449.
EN 12735 Seamless, Round Copper Tubes for Air Conditioning and Refrigeration - Dimensions
Dimensions of seamless, round copper tubes for air conditioning and refrigeration piping systems.
EN 13348 Seamless, Round Copper Tubes for Medical Gases or Vacuum - Dimensions
Dimensions of seamless round copper and copper alloys tubes for medical gases or vacuum.
Friction Loss in Steel, Copper and Plastic Pipes
Friction head loss (ft/100 ft) vs. water flow in steel, copper and PVC plastic pipes.
Hot Water Heating System Online Design Application
Insulated Copper Tubes - Heat Loss
Heat loss to surrounding air from insulated copper tubes.
Nickel and Nickel Alloy Pipes - Temperature Ranges
Temperature ranges for bending nickel and nickel alloy pipes and tubes.
Pipes and Tubes - Imperial vs. Metric Sizes
SI vs. Imperial pipe sizes.
Pipes and Tubes - Water Content
Water content in steel pipes and copper tubes.
Solder Joints - Pressure Ratings vs. Temperature
Solder joints and their pressure ratings according ASME B16.18.
