Pipes and Tubes - Water Content
Steel Pipes
Steel Pipes - Water Content
Nominal Pipe Size
(in)
Water Content (gal/ft)
Schedule 40Schedule 80
1/8 0.0030 0.0019
1/4 0.0054 0.0037
3/8 0.0099 0.0073
1/2 0.0158 0.0122
3/4 0.0277 0.0225
1 0.0449 0.0374
Copper Tubes
Copper Tubes - Water Content
Nominal Pipe Size
(in)
Type KType LType M
1/8 0.0014 0.0016 0.0016
1/4 0.0039 0.0040 0.0043
3/8 0.0066 0.0075 0.0083
1/2 0.0113 0.0121 0.0132
5/8 0.0173 0.0181 0.0194
3/4 0.0226 0.0251 0.0268
1 0.0404 0.0429 0.0454
  • 1 in = 25.4 mm
  • 1 ft = 0.3048 m
  • 1 Gallon (U.S.) = 3.785x10-3 m3 = 3.785 dm3 (liter) = 231 in3 = 0.13368 ft3 = 4.951x10-3 yd3 = 0.8327 Imp. gal (UK) = 4 Quarts = 8 Pints
Sizing of Steam and Condensate Pipes
Dimensions of steam and condensate pipe lines. Calculate pressure losses, recommended velocities, capacities and more.
ANSI Steel Pipe Schedule 40 Chart: Dimensions, Weights & Specifications
ASTM B88 - Seamless Copper Water Tubes - Dimensions
BS 2871 Copper Tubes Table X, Y and Z - Working Pressures vs. Size
Content in Horizontal - or Sloped - Cylindrical Tanks or Pipes
Volume of partly filled horizontal or sloped cylindrical tanks or pipes - online calculator.
Copper Tubes Type K - Dimensions and Physical Characteristics
Physical characteristics of copper tubes ASTM B 88 type K.
Pipes with Water Content - Weight and Volume
Estimate water content in pipes - weight and volume.
Piping Equations
Calculate cross-sectional areas, weight of empty pipes, weight of pipes filled with water, inside and outside surface areas.
Volume in Horizontal Pipes or Cylindrical Tanks
Liquid content in partly filled horizontal pipes or tanks.
