ASTM B88 - Seamless Copper Water Tubes - Dimensions
Dimensions of copper tubes according ASTM B88 Standard Specification for Seamless Copper Water Tube can be found in the tables below.
ASTM B88 - Seamless Copper Water Tubes - Dimensions - Type K
Nominal Size
(inches)
Actual Outside Diameter
(inches)
Tolerance on Outside Diameter
(inches)
Wall Thickness
(inches)
Weight
(lb/ft)
Annealed1)Drawn2)NominalTolerance
1/4 3/8 0.375 0.002 0.001 0.035 0.0035 0.133
3/8 1/2 0.500 0.0025 0.001 0.049 0.005 0.269
1/2 5/8 0.625 0.0025 0.001 0.049 0.005 0.344
5/8 3/4 0.750 0.0025 0.001 0.049 0.005 0.418
3/4 7/8 0.875 0.003 0.001 0.065 0.006 0.641
1 1 1/8 1.125 0.0035 0.0015 0.065 0.006 0.837
1 1/4 1 3/8 1.375 0.004 0.0015 0.065 0.006 1.04
1 1/2 1 5/8 1.625 0.0045 0.002 0.072 0.007 1.36
2 2 1/8 2.125 0.005 0.002 0.083 0.008 2.06
2 1/2 2 5/8 2.625 0.005 0.002 0.095 0.010 2.92
3 3 1/8 3.125 0.005 0.002 0.109 0.011 4.00
3 1/2 3 5/8 3.625 0.005 0.002 0.120 0.012 5.12
4 4 1/8 4.125 0.005 0.002 0.134 0.013 6.51
5 5 1/8 5.125 0.005 0.002 0.160 0.016 9.67
6 6 1/8 6.125 0.005 0.002 0.192 0.019 13.87
Copper tubes of type K are thick walled, much thicker than type L and M and are used for domestic water-, service and distribution-, fire protection-, solar-, fuel and oil-, HVAC-, compressed air-, oxygen-, LPG gas-, snow melting-, steam- and vacuum-systems.
For all sizes - outside diameter is 1/8 inch larger than the standard size designation.
Be careful with copper tubes and natural gas. Due to odor additives, moisture content and type of solders used the tubes may crack. Copper tubes is not allowed by code in the U.S. for natural gas distribution.
Copper tubes of type K can be used sweat, flared and compression fittings. Available in hard and soft types.
ASTM B88 - Seamless Copper Water Tubes - Dimensions - Type L
Nominal Size
(inches)
(inches)
(inches)
Wall Thickness
(inches)
Weight
(lb/ft)
1/4 3/8 0.375 0.002 0.001 0.030 0.003 0.126
3/8 1/2 0.500 0.0025 0.001 0.035 0.004 0.198
1/2 5/8 0.625 0.0025 0.001 0.040 0.004 0.285
5/8 3/4 0.750 0.0025 0.001 0.042 0.004 0.362
3/4 7/8 0.875 0.003 0.001 0.045 0.004 0.455
1 1 1/8 1.125 0.0035 0.0015 0.050 0.005 0.655
1 1/4 1 3/8 1.375 0.004 0.0015 0.055 0.006 0.884
1 1/2 1 5/8 1.625 0.0045 0.002 0.060 0.006 1.14
2 2 1/8 2.125 0.005 0.002 0.070 0.007 1.75
2 1/2 2 5/8 2.625 0.005 0.002 0.080 0.008 2.48
3 3 1/8 3.125 0.005 0.002 0.090 0.009 3.33
3 1/2 3 5/8 3.625 0.005 0.002 0.100 0.010 4.29
4 4 1/8 4.125 0.005 0.002 0.114 0.011 5.38
5 5 1/8 5.125 0.005 0.002 0.125 0.012 7.61
6 6 1/8 6.125 0.005 0.002 0.140 0.014 10.20
Standard copper tubes of type L are used for interior above ground plumbing - domestic water-, service and distribution-, fire protection-, solar-, fuel and oil-, HVAC-, compressed air-, LPG gas-, snow melting- and vacuum-systems.
Copper tubes of type L can be used with sweat, compression and flare fittings. Available in hard and soft types.
ASTM B88 - Seamless Copper Water Tubes - Dimensions - Type M
Nominal Size
(inches)
(inches)
(inches)
Wall Thickness
(inches)
Weight
(lb/ft)
1/4 3/8 0.375 0.002 0.001 0.106
3/8 1/2 0.500 0.0025 0.001 0.025 0.002 0.144
1/2 5/8 0.625 0.0025 0.001 0.028 0.003 0.203
5/8 3/4 0.750 0.0025 0.001 0.263
3/4 7/8 0.875 0.003 0.001 0.032 0.003 0.328
1 1 1/8 1.125 0.0035 0.0015 0.035 0.004 0.464
1 1/4 1 3/8 1.375 0.004 0.0015 0.042 0.004 0.681
1 1/2 1 5/8 1.625 0.0045 0.002 0.049 0.005 0.94
2 2 1/8 2.125 0.005 0.002 0.058 0.006 1.46
2 1/2 2 5/8 2.625 0.005 0.002 0.065 0.006 2.03
3 3 1/8 3.125 0.005 0.002 0.072 0.007 2.68
3 1/2 3 5/8 3.625 0.005 0.002 0.083 0.008 3.58
4 4 1/8 4.125 0.005 0.002 0.095 0.010 4.66
5 5 1/8 5.125 0.005 0.002 0.109 0.011 6.66
6 6 1/8 6.125 0.005 0.002 0.122 0.012 8.91
Copper tubes of type M are used for interior domestic water-, service and distribution-, fire protection-, solar-, fuel and oil-, HVAC-,  snow melting- and vacuum-systems. Wall thickness less than type K and L.
Copper tubes type M are normally used with flare fittings. Available in soft and hard types.
  • 1 in (inch) = 25.4 mm
1) Annealed tube is suitable for use with flared or compression fittings, and with solder-type fittings, provided rounding and sizing of the tube ends is performed where needed.
2) Drawn temper tube is suitable for use with solder-type fittings. Types A and B tube, in the drawn temper, are suitable for use with certain types and sizes of compression fittings. The standard length for drawn tubes are 20 ft (6.096 m).
The B88 specification covers seamless copper water tube suitable for general plumbing, similar applications for the conveyance of fluids, and commonly used with solder, flared, or compression-type fittings. The type of copper water tube suitable for any particular application is determined by the internal or external fluid pressure, by the installation and service conditions, and by local requirements. Means of joining or bending are also factors that affect the selection of the type of tube to be used.
This specification is the imperial companion of Specification B 88M.
Dimensions of Pipes and Tubes
ASTM B280 Copper Tube for Air Conditioning and Refrigeration (ACR) - Dimensions and Working Pressures
Standard specifications for seamless copper tube used in Air Conditioning and Refrigeration Field Services.
ASTM B302 - Threadless Copper Pipes - Dimensions
ASTM B306 Copper Tubes for Drain, Waste and Vent - Dimensions and Working Pressures
ASTM B42 - Seamless Copper Pipes - Dimensions
ASTM B43 - Seamless Red Brass Pipes - Dimensions
Standard sizes specification for seamless red brass pipes.
ASTM B819 Seamless Copper Tubes for Medical Gas Systems - Dimensions
Dimensions of copper tubes used in medical gas systems.
ASTM B837 - Seamless Copper Tubes for Natural Gas and Liquified Petroleum - Dimensions
ASTM B88M - Seamless Copper Water Tubes - Metric Dimensions
Water and gas copper tubes according ASTM B88M - type K, L and M - metric units.
ASTM International
ASTM International - American Society for Testing and Materials - is a scientific and technical organization that develops and publishes voluntary standards on the characteristics of material, products, systems and services.
BS 2871 Copper Tubes Table X, Y and Z - Working Pressures vs. Size
Copper - Density, Specific Heat and Thermal Conductivity vs. Temperature
Density, specific heat and thermal conductivity of copper vs. temperature
Copper and Copper Alloy Pipes - Temperature Ranges
Bending copper pipe and tube temperatures.
Copper Tubes - Corrosion Resistance to Chemicals
Copper tubes corrosion resistance to different products and chemicals.
Copper Tubes - Heat Carrying Capacities
Hot water heat carrying capacities in copper tubes type L.
Copper Tubes - Maximum Water Velocities
Water velocity in a copper tube should not exceed certain limits to avoid erosion.
Copper Tubes - Pressure Loss vs. Water Flow
Water flow and pressure loss (psi/ft) due to friction in copper tubes ASTM B88 Types K, L and M.
Copper Tubes - Uninsulated Heat Losses
Heat loss from uninsulated copper pipes - dimensions ranging 1/2 - 4 inches.
Copper Tubes Supports
Maximum space between supports aand clips for copper tubes.
Copper Tubes Type K - Dimensions and Physical Characteristics
Physical characteristics of copper tubes ASTM B 88 type K.
Copper Tubes Type K, L and M - Working Pressures vs. Size
EN 1057 Copper Tubes for Water and Gas in Sanitary and Heating Applications - Dimensions
Dimensions of EN 1057 Copper and copper alloys - Seamless, round copper tubes for water and gas in sanitary and heating applications.
EN 12449 - Copper and Copper Alloys - Seamless, Round Tubes for General Purposes - Dimensions
Dimensions of copper tubes according EN 12449.
EN 12735 Seamless, Round Copper Tubes for Air Conditioning and Refrigeration - Dimensions
Dimensions of seamless, round copper tubes for air conditioning and refrigeration piping systems.
EN 13348 Seamless, Round Copper Tubes for Medical Gases or Vacuum - Dimensions
Dimensions of seamless round copper and copper alloys tubes for medical gases or vacuum.
Friction Loss in Steel, Copper and Plastic Pipes
Friction head loss (ft/100 ft) vs. water flow in steel, copper and PVC plastic pipes.
Hot Water Heating System Online Design Application
Nickel and Nickel Alloy Pipes - Temperature Ranges
Temperature ranges for bending nickel and nickel alloy pipes and tubes.
NPS (Nominal Pipe Size) Guide: Dimensions, Charts & Specifications
The size of pipes, fittings, flanges and valves are often given in inches as NPS - Nominal Pipe Size, or in metric units as DN - 'Diametre Nominal'.
Pipe vs. Tube
Pipes and tubes are not exactly the same
Pipes and Tubes - Water Content
Water content in steel pipes and copper tubes.
Piping Materials - Cost Ratios
Solder Joints - Pressure Ratings vs. Temperature
Solder joints and their pressure ratings according ASME B16.18.
