ASTM B280 Copper Tube for Air Conditioning and Refrigeration (ACR) - Dimensions and Working Pressures
Seamless copper tube according ASTM B280 – Standard Specification for Seamless Copper Tube for Air Conditioning and Refrigeration Field Service - is intended for use in the connection, repairs, or alternations of air conditioning or refrigeration units in the field.
ACR Copper Tubes is used in the Air Conditioning and Refrigeration Field Service Industry and is produced in straight lengths or coils.
Copper tube for air-conditioning and refrigeration field service (ACR) is designated by actual outside diameter.
Nominal Size (inches) | Annealed (A) or Drawn Temper (D) | Outside Diameter (inches) | Inside Diameter (inches) | Wall Thickness (inches) | Cross Sectional Area of Bore (square inches) |
1/8 | A | 0.125 | 0.065 | 0.030 | 0.0033 |
3/16 | A | 0.187 | 0.128 | 0.030 | 0.0129 |
1/4 | A | 0.250 | 0.190 | 0.030 | 0.0284 |
5/16 | A | 0.312 | 0.248 | 0.032 | 0.0483 |
3/8 | A | 0.375 | 0.311 | 0.032 | 0.076 |
D | 0.375 | 0.315 | 0.030 | 0.078 | |
1/2 | A | 0.500 | 0.436 | 0.032 | 0.149 |
D | 0.500 | 0.430 | 0.035 | 0.145 | |
5/8 | A | 0.625 | 0.555 | 0.035 | 0.242 |
D | 0.625 | 0.545 | 0.040 | 0.233 | |
3/4 | A | 0.750 | 0.680 | 0.035 | 0.363 |
A | 0.750 | 0.666 | 0.042 | 0.348 | |
D | 0.750 | 0.666 | 0.042 | 0.348 | |
7/8 | A | 0.875 | 0.785 | 0.045 | 0.484 |
D | 0.875 | 0.785 | 0.045 | 0.484 | |
1 1/8 | A | 1.125 | 1.025 | 0.050 | 0.825 |
D | 1.125 | 1.025 | 0.050 | 0.825 | |
1 3/8 | A | 1.375 | 1.265 | 0.055 | 1.26 |
D | 1.375 | 1.265 | 0.055 | 1.26 |
Temper describes the strength and hardness of the tube.
- drawn temper - also called "hard" or "rigid"
- annealed temper - also called "soft" or "flexible"
Working Pressures
Nominal Size (inches) | Max. Working Pressure (psi) | ||
Annealed Coils | Annealed Straight Lengths | Drawn Straight Lengths | |
1/8 | 2613 | ||
3/16 | 1645 | ||
1/4 | 1195 | ||
5/19 | 1017 | ||
3/8 | 836 | 777 | 1524 |
1/2 | 618 | 664 | 1302 |
5/8 | 525 | 615 | 1206 |
3/4 | 435 | 538 | 1055 |
7/8 | 495 | 496 | 972 |
1 1/8 | 420 | 421 | 825 |
1 3/8 | 373 | 374 | 733 |
1 5/8 | 347 | 348 | 682 |
2 1/8 | 309 | 607 | |
2 5/8 | 286 | 560 | |
3 1/8 | 270 | 529 | |
3 5/8 | 258 | 506 | |
4 1/8 | 249 | 489 |
Ratings based on service temperature max. 150 oF (66 oC).
- yield strength S = 5100 psi (35 GPa) for annealed tube
- yield strength S = 10000 psi (69GPa) for drawn tube
• Air Conditioning Systems
Standard specifications for seamless copper tube used in Air Conditioning and Refrigeration Field Services.
ASTM B302 - Threadless Copper Pipes - Dimensions
ASTM B306 Copper Tubes for Drain, Waste and Vent - Dimensions and Working Pressures
ASTM B42 - Seamless Copper Pipes - Dimensions
ASTM B837 - Seamless Copper Tubes for Natural Gas and Liquified Petroleum - Dimensions
ASTM B88 - Seamless Copper Water Tubes - Dimensions
ASTM B88M - Seamless Copper Water Tubes - Metric Dimensions
Water and gas copper tubes according ASTM B88M - type K, L and M - metric units.
BS 2871 Copper Tubes Table X, Y and Z - Working Pressures vs. Size
Copper Tubes - Corrosion Resistance to Chemicals
Copper tubes corrosion resistance to different products and chemicals.
Copper Tubes - Equivalent Length Pressure Loss in Fittings and Valves
Copper tube fittings and equivalent lengths - in feets of straight tube.
Copper Tubes - Pressure Loss vs. Water Flow
Water flow and pressure loss (psi/ft) due to friction in copper tubes ASTM B88 Types K, L and M.
Copper Tubes - Uninsulated Heat Losses
Heat loss from uninsulated copper pipes - dimensions ranging 1/2 - 4 inches.
Copper Tubes Supports
Maximum space between supports aand clips for copper tubes.
Copper Tubes Type K - Dimensions and Physical Characteristics
Physical characteristics of copper tubes ASTM B 88 type K.
Copper Tubes Type K, L and M - Working Pressures vs. Size
EN 1057 Copper Tubes for Water and Gas in Sanitary and Heating Applications - Dimensions
Dimensions of EN 1057 Copper and copper alloys - Seamless, round copper tubes for water and gas in sanitary and heating applications.
EN 12449 - Copper and Copper Alloys - Seamless, Round Tubes for General Purposes - Dimensions
Dimensions of copper tubes according EN 12449.
EN 12735 Seamless, Round Copper Tubes for Air Conditioning and Refrigeration - Dimensions
Dimensions of seamless, round copper tubes for air conditioning and refrigeration piping systems.
EN 13348 Seamless, Round Copper Tubes for Medical Gases or Vacuum - Dimensions
Dimensions of seamless round copper and copper alloys tubes for medical gases or vacuum.
Horizontal Pipe Hanger Supports - Spacing and Rod Size
Recommended maximum support span between hangers - and rod sizes for straight horizontal pipes.
Pipe vs. Tube
Pipes and tubes are not exactly the same
Solder Joints - Pressure Ratings vs. Temperature
Solder joints and their pressure ratings according ASME B16.18.
