ASTM B306 Copper Tubes for Drain, Waste and Vent - Dimensions and Working Pressures
Copper tubes according ASTM 306 are used in soil, waste, vent, solar and storm drainage piping systems.
DWV stands for "Drain, Waste and Vent" and is pipes recommended for above ground use only, no pressure applications and sweat fittings only..
Nominal Diameter
(in)
Outside Diameter
(in)
Inside Diameter
(in)
Wall Thickness
(in)
Cross Sectional Area of Bore
(in2)
Mass (Weight) per unit Length
(lb/ft)
Mass (Weight) with Water
(lb/ft)
1 1/4 1.375 1.295 0.040 1.32 0.650 1.22
1 1/2 1.625 1.541 0.042 1.87 0.81 1.62
2 2.125 2.041 0.042 3.27 1.07 2.48
3 3.125 3.030 0.045 7.21 1.69 4.81
4 4.125 4.009 0.058 11.6 2.87 7.88
5 5.125 4.981 0.072 19.5 4.43 12.9
6 6.125 5.959 0.083 27.9 6.10 18.2
  • recommended for above ground and no pressure applications only
  • sweat fittings only
  • available only in hard type
  • 1 in2 = 645.2 mm2
  • 1 lb/ft = 1.49 kg/m
Working Pressures
Ratings based on service temperature max. 150 oF (66 oC)
  • yield strength S = 5100 psi (35 GPa) for annealed tube
  • yield strength S = 10000 psi (69GPa) for drawn tube
ASTM B306 Copper Tubes for Drain, Waste and Vent - Working Pressures
Nominal Size
(in)
Max. Working Pressure (psi)
AnnealedDrawn
1 1/4 280 549
1 1/2 249 489
2 185 362
3 135 265
4 127 250
5 129 252
6 126 247
8 124 244
Pressure Ratings of Pipes and Fittings
Sanitary Drainage Systems
The purpose of the sanitary drainage system is to remove effluent discharged from plumbing fixtures and other equipment.
ASME/ANSI B16 Standards for Pipes and Fittings
The ASME B16 standards covers pipes and fittings in cast iron , cast bronze, wrought copper and steel.
ASTM B280 Copper Tube for Air Conditioning and Refrigeration (ACR) - Dimensions and Working Pressures
Standard specifications for seamless copper tube used in Air Conditioning and Refrigeration Field Services.
ASTM B302 - Threadless Copper Pipes - Dimensions
ASTM B42 - Seamless Copper Pipes - Dimensions
ASTM B43 - Seamless Red Brass Pipes - Dimensions
Standard sizes specification for seamless red brass pipes.
ASTM B837 - Seamless Copper Tubes for Natural Gas and Liquified Petroleum - Dimensions
ASTM B88 - Seamless Copper Water Tubes - Dimensions
ASTM International
ASTM International - American Society for Testing and Materials - is a scientific and technical organization that develops and publishes voluntary standards on the characteristics of material, products, systems and services.
BS 2871 Copper Tubes Table X, Y and Z - Working Pressures vs. Size
Copper Tubes - Corrosion Resistance to Chemicals
Copper tubes corrosion resistance to different products and chemicals.
Copper Tubes - Equivalent Length Pressure Loss in Fittings and Valves
Copper tube fittings and equivalent lengths - in feets of straight tube.
Copper Tubes - Pressure Loss vs. Water Flow
Water flow and pressure loss (psi/ft) due to friction in copper tubes ASTM B88 Types K, L and M.
Copper Tubes Supports
Maximum space between supports aand clips for copper tubes.
Copper Tubes Type K - Dimensions and Physical Characteristics
Physical characteristics of copper tubes ASTM B 88 type K.
Copper Tubes Type K, L and M - Working Pressures vs. Size
Drain Pipes and Vent Stacks
Drain pipes and vent stack sizing.
Drain Waste and Vent Pipes - Hanger Spacing
Support of Drain Waste and Vent - DWV - pipes.
EN 1057 Copper Tubes for Water and Gas in Sanitary and Heating Applications - Dimensions
Dimensions of EN 1057 Copper and copper alloys - Seamless, round copper tubes for water and gas in sanitary and heating applications.
EN 12735 Seamless, Round Copper Tubes for Air Conditioning and Refrigeration - Dimensions
Dimensions of seamless, round copper tubes for air conditioning and refrigeration piping systems.
EN 13348 Seamless, Round Copper Tubes for Medical Gases or Vacuum - Dimensions
Dimensions of seamless round copper and copper alloys tubes for medical gases or vacuum.
Fixtures Trap Sizes
Recommended drain trap sizes for different types of fixtures
Horizontal Pipe Hanger Supports - Spacing and Rod Size
Recommended maximum support span between hangers - and rod sizes for straight horizontal pipes.
Sanitary Drainage Systems - Volume Flow
Calculate expected volume flow load in sanitary drainage systems.
