Metals - Latent Heat of Melting
The Latent Heat of Fusion is the heat supplied to a solid body at the melting point when it changes state from solid to liquid.
Latent heat of fusion for some metals are indicated below:
Metal | Symbol | Atomic Weight (g/mol) | Latent Heat of Melting | |
(kJ/mol) | (kJ/kg) | |||
Aluminum | Al | 27 | 10.7 | 396 |
Antimony | Sb | 122 | 19.7 | 161 |
Beryllium | Be | 9.1 | 7.95 | 1356 |
Bismuth | Bi | 209 | 10.9 | 52.2 |
Cadmium | Cd | 112 | 6.3 | 56 |
Chromium | Cr | 52.0 | 20.5 | 394 |
Cobalt | Co | 58.9 | 16.2 | 275 |
Copper | Cu | 63.5 | 13.1 | 206 |
Gold | Au | 197 | 12.5 | 63 |
Iridium | Ir | 192 | 26 | 135 |
Iron | Fe | 55.8 | 13.8 | 247 |
Lead | Pb | 207 | 4.77 | 23 |
Magnesium | Mg | 24.3 | 8.7 | 358 |
Manganese | Mn | 54.9 | 13.2 | 240 |
Mercury | Hg | 201 | 2.29 | 11.4 |
Molybdenum | Mo | 95.9 | 36 | 375 |
Nickel | Ni | 58.7 | 17.2 | 293 |
Niobium | Nb | 92.9 | 26.8 | 288 |
Osmium | Os | 190 | 31 | 163 |
Platinum | Pt | 195 | 20 | 103 |
Plutonium | Pu | 244 | ||
Potassium | K | 39.1 | 2.33 | 56 |
Rhodium | Rh | 103 | 21.7 | 211 |
Selenium | Se | 79 | 5.4 | 68 |
Silicon | Si | 28.1 | 50.2 | 1787 |
Silver | Ag | 108 | 11.3 | 105 |
Sodium | Na | 23 | 2.6 | 113 |
Tantalum | Ta | 271 | 36 | 199 |
Thorium | Th | 232 | 16 | 69 |
Tin | Sn | 119 | 7 | 59 |
Titanium | Ti | 47.9 | 18.7 | 390 |
Tungsten | W | 184 | 35 | 190 |
Uranium | U | 238 | 14 | 59 |
Vanadium | V | 50.9 | 22.8 | 448 |
Zinc | Zn | 65.4 | 7.35 | 112 |
- 1 kJ/kg = 0.23884 cal/g = 0.23884 kcal/kg = 0.4299 Btu/lbm
Latent heat of fusion is calculated as
L = 1000 Lmol / A (1)
L = latent heat of fusion (kJ/kg)
Lmol = latent heat of fusion (kJ/mol)
A = atomic weight (g/mol)
Note that atomic mass and atomic weight are two different things. Atomic mass is the mass of an individual element. Atomic weight is the average mass of all the isotopes of an element. Force is not involved.
Beryllium - Specific Heat vs. Temperatures
Specific heat of beryllium related to temperature.
Iron - Density, Specific Heats and Thermal Conductivities vs. Temperatures
Specific heat, density and thermal conductivity of iron related to temperature.
Lead Binary Eutectic Alloys - Melting Points
Pb - Lead (Plumbum) - binary eutectic alloys and melting points.
Magnesium Binary Eutectic Alloys - Melting Points
Mg - Magnesium - binary eutectic alloys and melting points.
Metals - Boiling Temperatures
Metals and their boiling temperatures.
Metals - Specific Heats
Solids and Metals - Specific Gravities
Specific gravity for common solids and metals like aluminum, asbestos, brass, calcium and many others.
