Metals and Alloys - Densities
The density of some common metals, metallic elements and alloys are indicated in the table below:
Metal or Alloy | Density - ρ - (kg/m3) |
Actinium | 10070 |
Admiralty Brass | 8525 |
Aluminum | 2712 |
Aluminum - melted | 2560 - 2640 |
Aluminum alloy - 1100 | 2720 |
Aluminum alloy 2014, annealed | 2800 |
Aluminum alloy 3003, rolled | 2730 |
Aluminum alloy 360 | 2640 |
Aluminum alloy 2024-T6 | 2770 |
Aluminum alloy - 6061 | 2720 |
Aluminum alloy - 7050 | 2800 |
Aluminum alloy - 7178 | 2830 |
Aluminum bronze (3-10% Al) | 7700 - 8700 |
Aluminum foil | 2700 -2750 |
Antifriction metal | 9130 -10600 |
Antimony | 6690 |
Antimonial lead (hard lead) | 10900 |
Babbitt | 7272 |
Barium | 3594 |
Beryllium | 1840 |
Beryllium copper | 8100 - 8250 |
Bismuth | 9750 |
Brass - casting | 8400 - 8700 |
Brass - rolled and drawn | 8430 - 8730 |
Brass 60/40 | 8520 |
Bronze - lead | 7700 - 8700 |
Bronze - phosphorous | 8780 - 8920 |
Bronze (8-14% Sn) | 7400 - 8900 |
Brushed metal | 7860 |
Cadmium | 8640 |
Caesium | 1873 |
Calcium | 1540 |
Cartridge brass (70% Cu, 30% Zn)) | 8530 |
Cast iron | 6800 - 7800 |
Cerium | 6770 |
Chemical Lead | 11340 |
Chromium | 7190 |
Cobalt | 8746 |
Constantan | 8920 |
Columbium | 8600 |
Constantan | 8880 |
Copper | 8940 |
Cupronickel | 8908 - 8940 |
Delta metal | 8600 |
Duralumin | 2790 |
Dysprosium | 8550 |
Electrum (natural alloy silver and gold) | 12500 - 15000 |
Erbium | 9070 |
Eroded metal | 7860 |
Europium | 5243 |
Gadolinium | 7900 |
Gallium | 5907 |
Germanium | 5323 |
Gold | 19320 |
Hafnium | 13310 |
Hastelloy C | 8940 |
Holmium | 8800 |
Indium | 7310 |
Inconel | 8497 |
Incoloy | 8027 |
Iridium | 22650 |
Iron | 7850 |
Lanthanum | 6145 |
Lead | 11340 |
Light alloy based on Al | 2560 - 2800 |
Light alloy based on Mg | 1760 - 1870 |
Lithium | 534 |
Lutetium | 9840 |
Magnesium | 1738 |
Magnesium alloy AZ31B | 1770 |
Manganese | 7440 |
Manganese Bronze | 8359 |
Manganin | 8500 |
Mercury | 13593 |
Molybdenum | 10188 |
Monel | 8360 - 8840 |
Neodymium | 7007 |
Neptunium | 20200 |
Nichrome | 8400 |
Nickel | 8908 |
Nickel 20 | 8090 |
Nickel 200 | 8890 |
Nickel silver | 8400 - 8900 |
Nickeline | 8770 |
Nimonic | 8100 |
Niobium | 8570 |
Osmium | 22610 |
Palladium | 12160 |
Phosphor bronze | 8900 |
Platinum | 21400 |
Plutonium | 19816 |
Polonium | 9200 |
Potassium | 890 |
Praseodymium | 6770 |
Promethium | 7260 |
Protactinium | 15400 |
Radium | 5000 |
Red Brass | 8746 |
Rhenium | 20800 |
Rhodium | 12400 |
Rubidium | 1530 |
Ruthenium | 12100 |
Samarium | 7520 |
Scandium | 2990 |
Silver | 10490 |
Sodium | 971 |
Solder 50/50 Pb Sn | 8885 |
Stainless Steel | 7480 - 8000 |
Steel | 7850 |
Strontium | 2640 |
Tantalum | 16400 |
Technetium | 11000 |
Terbium | 8230 |
Tin | 7280 |
Titanium | 4500 |
Thallium | 11873 |
Thorium | 11700 |
Thulium | 9320 |
Tungsten | 19600 |
Uranium | 18900 |
Vanadium | 5494 |
White metal | 7100 |
Wrought Iron | 7750 |
Yellow Brass | 8470 |
Ytterbium | 6900 |
Yttrium | 4470 |
Zinc | 7135 |
Zirconium | 6570 |
- 1 kg/m3 = 0.0624 lb/ft3 = 0.000036127 lb/in3
- Unit Converter
Elements - Densities vs. Temperature
Densities of
- Al - Aluminum
- Be - Beryllium (polycrystalline form)
- Cr - Chromium
- Cu - Copper
- Au - Gold
- Ir - Iridium
- Fe - Iron
- Pb - Lead
- Mo - Molybdenum
- Ni - Nickel
- Pt - Platinum
- Ag - Silver
- Zn - Zinc
vs. temperature are indicated in the chart below.
• Densities
Alloy Steels
Alloy steels have properties due to elements other than carbon.
Aluminum - Thermophysical Properties
Density, specific heat and thermal conductivity related to temperature.
Aluminum Alloys - Mechanical Properties
Mechanical properties of some common aluminum alloys.
Mechanical properties of aluminum alloys - tensile strength, yield strength and more.
ASTM B43 - Seamless Red Brass Pipes - Dimensions
Standard sizes specification for seamless red brass pipes.
Beryllium - Specific Heat vs. Temperatures
Specific heat of beryllium related to temperature.
Bronze Flanges - ASME/ANSI 150 lb
Flange diameters, thickness, bolt circles, numbers and diameters of bolts for ASME/ANSI B16.15 - Cast Bronze Threaded Fittings - 150 lb Bronze flanges with plain faces.
Chromium - Specific Heat and Thermal Conductivities vs. Temperatures
Specific heat and thermal conductivity of chromium related to temperature.
Copper - Density, Specific Heat and Thermal Conductivity vs. Temperature
Density, specific heat and thermal conductivity of copper vs. temperature
Copper, Zinc and Tin Alloys
Strength of Copper, Zinc and Tin alloys.
Iron - Density, Specific Heats and Thermal Conductivities vs. Temperatures
Specific heat, density and thermal conductivity of iron related to temperature.
Lead Binary Eutectic Alloys - Melting Points
Pb - Lead (Plumbum) - binary eutectic alloys and melting points.
Magnesium Binary Eutectic Alloys - Melting Points
Mg - Magnesium - binary eutectic alloys and melting points.
Metal Alloys - Specific Heats
Specific heat of metal alloys like brass, bronze and more.
Metals - Machinability
The machinability of some common metals.
Metals - Specific Heats
Nickel Binary Eutectic Alloys - Melting Points
Ni - Nickel - binary eutectic alloys and melting points.
Pipe Weight Calculator
Silver Binary Eutectic Alloys - Melting Points
Ag - Silver - binary eutectic alloys and melting points.
Solids - Densities
Densities of selected solids.
Stainless Steel - Specific Heat and Thermal Conductivities vs. Temperatures
Specific heat and thermal conductivity of stainless steel vs. temperature
