Stainless Steel - Specific Heat and Thermal Conductivities vs. Temperatures
T (K) | c (kJ/kg K) | k (W/m K) |
100 | 0.272 | 9.2 |
200 | 0.402 | 12.6 |
300 | 0.477 | 14.9 |
400 | 0.515 | 16.6 |
600 | 0.557 | 19.8 |
800 | 0.582 | 22.6 |
1000 | 0.611 | 25.4 |
1200 | 0.640 | 28.0 |
1500 | 0.682 | 31.7 |
AISI 310 Stainless Steel - Properties
Thermal diffusivity, specific heat capacity, density and thermal conductivity of stainless steel AISI 310 vs. temperature.
ASTM A270 Sanitary Stainless Steel Tubing - Dimensions
Dimensions of ASTM A270 sanitary steel tubes.
ASTM A312 Stainless Steel Pipes - Bursting and Collapsing Pressures
Theoretic bursting and collapsing pressures for stainless steel pipes ASTM A312.
EN 10312 - Welded Stainless Steel Tubes for the Conveyance of Aqueous Liquids Including Water for Human Consumption - Dimensions
Dimensions of welded stainless steel tubes according EN 10312.
Metals and Alloys - Densities
Stainless Steel - Comparing International Standards
Comparing international stainless steel standards from America (US), France, Germany, Italy, Japan, Russia, Spain, Sweden, England (UK) and the European Union.
Stainless Steel Pipes - Allowable Pressure vs. Schedule and Size
Allowable pressure for standard seamless A312-TP316/316L stainless steel pipes - temperatures 100oF to 750oF.
Stainless Steel Weld Fittings - ANSI/ASME B36.19
Dimensions of stainless steel weld fittings according ANSI/ASME B36.19.
