Bronze Flanges - ASME/ANSI 150 lb
Flange diameters, thickness, bolt circles, numbers and diameters of bolts for ASME/ANSI B16.15 - Cast Bronze Threaded Fittings - 150 lb Bronze flanges with plain faces can be found in the table below:
For full table with larger sizes - rotate the screen!
Pipe Size (inches) | 1/2 | 3/4 | 1 | 1 1/4 | 1 1/2 | 2 | 2 1/2 | 3 | 3 1/2 | 4 | 5 | 6 | 8 | 10 | 12 |
Diameter of Flange (inches) |
3 1/2 | 3 7/8 | 4 1/4 | 4 5/8 | 5 | 6 | 7 | 7 1/2 | 8 1/2 | 9 | 10 | 11 | 13 1/2 | 16 | 19 |
Thickness of Flange (inches) |
5/16 | 11/32 | 3/8 | 13/32 | 7/16 | 1/2 | 9/16 | 5/8 | 11/16 | 11/16 | 3/4 | 13/16 | 15/16 | 1 | 1 1/16 |
Diameter of Bolt Circle (inches) |
2 3/8 | 2 3/4 | 3 1/8 | 3 1/2 | 3 7/8 | 4 3/4 | 5 1/2 | 6 | 7 | 7 1/2 | 8 1/2 | 9 1/2 | 11 3/4 | 14 1/4 | 17 |
Numbers of Bolts | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 4 | 8 | 8 | 8 | 8 | 8 | 12 | 12 |
Diameter of Bolts (inches) |
1/2 | 1/2 | 1/2 | 1/2 | 1/2 | 3/4 | 3/4 | 3/4 | 3/4 | 3/4 | 3/4 | 3/4 | 3/4 | 7/8 | 7/8 |
150 lb bronze flanges with plain faces have two concentric gaskets retaining grooves between the port and the holes.
- 1 inch = 25.4 mm
• Piping Systems
ASME/ANSI B16 Standards for Pipes and Fittings
The ASME B16 standards covers pipes and fittings in cast iron , cast bronze, wrought copper and steel.
ASME/ANSI B16.5 Flanges and Bolt Dimensions - Class 150 to 2500
Diameters and bolt circles for standard ASME B16.5 flanges - 1/4 to 24 inches - Class 150 to 2500.
ASTM Flanges - Hydrostatic Test Pressures
Flanged fittings and required hydrostatic test pressure.
Carbon and Stainless Steel Welding Neck Flange Bores
Flange bores of welding neck flanges according ASME/ANSI B16.5-1996 Pipe Flanges and Flanged Fittings.
Carbon Steel Flanges - Group 1.1 Pressure and Temperature Ratings
Maximum temperature and pressure ratings of flanges conforming dimensions ASME B16.5 and materials specification ASTM A-105.
Carbon Steel Flanges - Pressure and Temperature Ratings
Maximum ratings for flanges conforming to ISO Standard 2229 dimensions and material specification AST-A-105.
Metal Alloys - Specific Heats
Specific heat of metal alloys like brass, bronze and more.
Metals and Alloys - Densities
Pipe Flanges and Gaskets - Dimensions
Gasket dimensions according ASME B16.5 Pipe Flanges and Flange Fittings.
PN Pressure Ratings for Flanges: Specifications & Standards
