ASME/ANSI B16.5 Flanges and Bolt Dimensions - Class 150 to 2500
Flange dimensions are determined by the pipe size and the pressure class required for the application. Flanges are standardized according publications from organizations like ASME, MSS, API and others.
ASME/ANSI B16.5 provides
  • weld neck
  • slip-on
  • socket weld
  • threaded
  • lap joint
  • blind
flange dimensions for pipes ranging 1/2" to 24" - in classes ranging 150 to 2500. Note that the ratings are in steps with terminology like ASME class xxx or API xxxx.
In general you need to specify the schedule (thickness) of the connected pipe when it is being butt welded to the flange. Socket welded and threaded connections is unaffected by wall thickness and should only require the OD.
Nominal Pipe Size
NPS
(inches)
Class 150
Diameter of
Flange
(inches)
No.
of
Bolts
Diameter of
Bolts
(inches)
Diameter of
Bolt Holes
(inches)
Bolt
Circle
(inches)
1/4 3-3/8 4 1/2 0.62 2-1/4
1/2 3-1/2 4 1/2 0.62 2-3/8
3/4 3-7/8 4 1/2 0.62 2-3/4
1 4-1/4 4 1/2 0.62 3-1/8
1-1/4 4-5/8 4 1/2 0.62 3-1/2
1-1/2 5 4 1/2 0.62 3-7/8
2 6 4 5/8 0.75 4-3/4
2-1/2 7 4 5/8 0.75 5-1/2
3 7-1/2 4 5/8 0.75 6
3-1/2 8-1/2 8 5/8 0.75 7
4 9 8 5/8 0.75 7-1/2
5 10 8 3/4 0.88 8-1/2
6 11 8 3/4 0.88 9-1/2
8 13-1/2 8 3/4 0.88 11-3/4
10 16 12 7/8 1 14-1/4
12 19 12 7/8 1 17
14 21 12 1 1.12 18-3/4
16 23-1/2 16 1 1.12 21-1/4
18 25 16 1-1/8 1.25 22-3/4
20 27-1/2 20 1-1/8 1.25 25
24 32 20 1-1/4 1.38 29-1/2
  • 1 inch = 25.4 mm
ASME/ANSI B16.5 Flanges and Bolt Dimensions - Class 300
Nominal Pipe Size
NPS
(inches)
Class 300
Diameter of
Flange
(inches)
No.
of
Bolts
Diameter of
Bolts
(inches)
Diameter of
Bolt Holes
(inches)
Bolt
Circle
(inches)
1/2 3-3/4 4 1/2 0.62 2-5/8
3/4 4-5/8 4 5/8 0.75 3-1/4
1 4-7/8 4 5/8 0.75 3-1/2
1-1/4 5-1/4 4 5/8 0.75 3-7/8
1-1/2 6-1/8 4 3/4 0.88 4-1/2
2 6-1/2 8 5/8 0.75 5
2-1/2 7-1/2 8 3/4 0.88 5-7/8
3 8-1/4 8 3/4 0.88 6-5/8
3-1/2 9 8 3/4 0.88 7-1/4
4 10 8 3/4 0.88 7-7/8
5 11 8 3/4 0.88 9-1/4
6 12-1/2 12 3/4 0.88 10-5/8
8 15 12 7/8 1 13
10 17-1/2 16 1 1.12 15-1/4
12 20-1/2 16 1-1/8 1.25 17-3/4
14 23 20 1-1/8 1.25 20-1/4
16 25-1/2 20 1-1/4 1.38 22-1/2
18 28 24 1-1/4 1.38 24-3/4
20 30-1/2 24 1-1/4 1.38 27
24 36 24 1-1/2 1.62 32
ASME/ANSI B16.5 Flanges and Bolt Dimensions - Class 400
Nominal Pipe Size
NPS
(inches)
Class 400
Diameter of
Flange
(inches)
No.
of
Bolts
Diameter of
Bolts
(inches)
Diameter of
Bolt Holes
(inches)
Bolt
Circle
(inches)
3-1/2 9 8 7/8 1 7-1/4
4 10 8 7/8 1 7-7/8
5 11 8 7/8 1 9-1/4
6 12-1/2 12 7/8 1 10-5/8
8 15 12 1 1.12 13
10 17-1/2 16 1-1/8 1.25 15-1/4
12 20-1/2 16 1-1/4 1.38 17-3/4
14 23 20 1-1/4 1.38 20-1/4
16 25-1/2 20 1-3/8 1.5 22-1/2
18 28 24 1-3/8 1.5 24-3/4
20 30-1/2 24 1-1/2 1.62 27
24 36 24 1-3/4 1.88 32
ASME/ANSI B16.5 Flanges and Bolt Dimensions - Class 600
Nominal Pipe Size
NPS
(inches)
Class 600
Diameter of
Flange
(inches)
No.
of
Bolts
Diameter of
Bolts
(inches)
Diameter of
Bolt Holes
(inches)
Bolt
Circle
(inches)
4 10-3/4 8 7/8 1 8-1/2
5 13 8 1 1.12 10-1/2
6 14 12 1 1.12 11-1/2
8 16-1/2 12 1-1/8 1.25 13-3/4
10 20 16 1-1/4 1.38 17
12 22 20 1-1/4 1.38 19-1/4
14 23-3/4 20 1-3/8 1.5 20-3/4
16 27 20 1-1/2 1.62 23-3/4
18 29-1/4 20 1-5/8 1.75 25-3/4
20 32 24 1-5/8 1.75 28-1/2
24 37 24 1-7/8 2 33
ASME/ANSI B16.5 Flanges and Bolt Dimensions - Class 900
Nominal Pipe Size
NPS
(inches)
Class 900
Diameter of
Flange
(inches)
No.
of
Bolts
Diameter of
Bolts
(inches)
Diameter of
Bolt Holes
(inches)
Bolt
Circle
(inches)
1/2 4-3/4 4 3/4 0.88 3-1/4
3/4 5-1/8 4 3/4 0.88 3-1/2
1 5-7/8 4 7/8 1 4
1-1/4 6-1/4 4 7/8 1 4-3/8
1-1/2 7 4 1 1.12 4-7/8
2 8-1/2 8 7/8 1 6-1/2
2-1/2 9-5/8 8 1 1.12 7-1/2
3 9-1/2 8 7/8 1 7-1/2
4 11-1/2 8 1-1/8 1.25 9-1/4
5 13-3/4 8 1-1/4 1.38 11
6 15 12 1-1/8 1.25 12-1/2
8 18-1/2 12 1-3/8 1.5 15-1/2
10 21-1/2 16 1-3/8 1.5 18-1/2
12 24 20 1-3/8 1.5 21
14 25-1/4 20 1-1/2 1.62 22
16 27-3/4 20 1-5/8 1.75 24-1/2
18 31 20 1-7/8 2 27
20 33-3/4 20 2 2.12 29-1/2
24 41 20 2-1/2 2.62 35-1/2
ASME/ANSI B16.5 Flanges and Bolt Dimensions - Class 1500
Nominal Pipe Size
NPS
(inches)
Class 1500
Diameter of
Flange
(inches)
No.
of
Bolts
Diameter of
Bolts
(inches)
Diameter of
Bolt Holes
(inches)
Bolt
Circle
(inches)
1 5-7/8 4 7/8 1 4
3 10-1/2 8 1-1/8 1.25 8
4 12-1/4 8 1-1/4 1.38 9-1/2
5 14-3/4 8 1-1/2 1.62 11-1/2
6 15-1/2 12 1-3/8 1.5 12-1/2
8 19 12 1-5/8 1.75 15-1/2
10 23 12 1-7/8 2 19
12 26-1/2 16 2 2.12 22-1/2
14 29-1/2 16 2-1/4 2.38 25
16 32-1/2 16 2-1/2 2.62 27-3/4
18 36 16 2-3/4 2.88 30-1/2
20 38-3/4 16 3 3.12 32-3/4
24 46 16 3-1/2 3.62 39
ASME/ANSI B16.5 Flanges and Bolt Dimensions - Class 2500
Nominal Pipe Size
NPS
(inches)
Class 2500
Diameter of
Flange
(inches)
No.
of
Bolts
Diameter of
Bolts
(inches)
Diameter of
Bolt Holes
(inches)
Bolt
Circle
(inches)
1/2 5-1/4 4 3/4 0.88 3-1/2
3/4 5-1/2 4 3/4 0.88 3-3/4
1 6-1/4 4 7/8 1 4-1/4
1-1/4 7-1/4 4 1 1.12 5-1/8
1-1/2 8 4 1-1/8 1.25 5-3/4
2 9-1/4 8 1 1.12 6-3/4
2-1/2 10-1/2 8 1-1/8 1.25 7-3/4
3 12 8 1-1/4 1.38 9
4 14 8 1-1/2 1.62 10-3/4
5 16-1/2 8 1-3/4 1.88 12-3/4
6 19 8 2 2.12 14-1/2
8 21-3/4 12 2 2.12 17-1/4
10 26-1/2 12 2-1/2 2.62 21-1/4
12 30 12 2-3/4 2.88 24-3/8
Insert flanges to your Sketchup model with the Engineering ToolBox Sketchup Extension
Dimensions of Pipes and Tubes
ANSI Steel Pipe Schedule 40 Chart: Dimensions, Weights & Specifications
ASME - American Society of Mechanical Engineers
ASME is one of the leading organizations in the world developing codes and standards.
ASME/ANSI B36.10/19 - Carbon, Alloy and Stainless Steel Pipe - Dimensions
Bronze Flanges - ASME/ANSI 150 lb
Flange diameters, thickness, bolt circles, numbers and diameters of bolts for ASME/ANSI B16.15 - Cast Bronze Threaded Fittings - 150 lb Bronze flanges with plain faces.
Carbon and Stainless Steel Welding Neck Flange Bores
Flange bores of welding neck flanges according ASME/ANSI B16.5-1996 Pipe Flanges and Flanged Fittings.
Pipes - Nominal Wall Thickness
Nominal wall thickness of seamless and welded carbon and alloy steel pipes
Steel Bolts - ASTM Grades
Steel Bolts - SAE Grades
Steel Pipe Flanges for Waterworks Services
U.S. Bolts: Tensile Strength & Proof Load Specifications
Unified Thread Standards: UNC & UNF Size Charts & Specifications
US Hex Bolts - Inches
ANSI/ASME B18.2.1 Dimensions of Hex Bolts - Imperial units.
US Hex Bolts - Metric
Wrench Size Conversion Chart – Metric (mm) to SAE (Inches)
Convert between metric and SAE (inch) wrench sizes with this comprehensive comparison chart. Find the closest equivalent sizes for your tools, whether working with US standard (SAE) or metric fasteners.
