Pipe Weight Calculator
Weight of Empty Pipe
Weight of empty pipe per unit length can be calculated as
wp = ρm Am
    = ρm π (do2 - di2) / 4
    = (π / 4) ρm (do2 - di2)                               (1)
wpweight of empty pipe per unit length (kg/m, lb/in)
ρm = density of pipe material (kg/m3, lb/in3)
Am = cross-sectional wall area of pipe (m2, in2)
do = outside diameter (m, in)
di = do - 2 t = inside diameter (m, in)
t = wall thickness (m, in)
Weight of Liquid in Pipe
Weight of liquid in pipes per unit length can be calculated as
wl = ρl Ai
    = ρl π (di / 2)2
    = (π / 4) ρl di2                                    (2)
wl = weight of liquid in pipe per unit length of pipe (kg, lb)
Ai = cross-sectional inside area of pipe (m2, in2)
ρl = density of liquid (kg/m3, lb/in3)
Weight of Pipe with Liquid
Weight of pipe with liquid can be calculated as
w = wp + wi
   = ρm Am + ρl Ai
   =  (ρm π (do2 - di2) / 4) + (ρl π di2 / 4)
   = (π / 4) (ρm (do2 - di2) + ρl di2)                      (3)
Weight of Pipe Calculator
This calculator can be used to calculate the weight of a pipe with - or without - liquid. The calculator is generic and can be used for both SI and Imperial units as long as the use of units are consistent.
  • 1 m = 103 mm
  • 1 m2 = 106 mm2
  • 1 in = 1/12 ft
  • 1 in2 = 1/144 ft2
  • 1 lb/in3 = 1728 lb/ft2
Example - Weight of 4" Schedule 40 Steel Pipe with Water - SI Units (default values in the calculator above)
The outside diameter  of 4" Schedule 40 Steel Pipe is 114.3 mm. The inside diameter is 102.3 mm. The density of steel is 7850 kg/m3. The density of water is 1000 kg/m3.
The weight of empty pipe per unit length can be calculatet with (1) as:
wp = (π / 4) (7850 kg/m3) ((0.1143 m)2 - (0.1023 m)2)
     = 16 kg/m
The weight of the liquid in the pipe per unit length can be calculatet with (2) as:
wl = (π / 4) (1000 kg/m3) (0.1023 m)2
     = 8.2 kg/m
The weight of pipe filled with water per unit length can be calculated with (3) as
w = (π / 4) ((7850 kg/m3)((0.1143 m)2 - (0.1023 m)2) + (1000 kg/m3) (0.1023 m)2
   = 24.2 kg/m
The outside diameter  of 4" Schedule 40 Steel Pipe is 4.500 inches. The wall thickness is 0.237 inches and the inside diameter is 4.026 in. The density of steel is 490 lb/ft3 (0.28 lb/in3). The weight of empty pipe per unit length can be calculated as
w = (π / 4) (0.28 lb/in3) ((4.500 in)2 - (4.026 in)2)
   = 0.89 lb/in
   = 10.7 lb/ft
Typical Weight of Schedule 40 Steel Pipe with/without Water
Nominal Pipe SizeWeight of PipeWeight of Pipe filled with Water
(in)(mm)(lbs/ft)(kg/m)(lbs/ft)(kg/m)
3/8 10 0.6 0.9 0.7 1.0
1/2 15 0.8 1.2 0.9 1.2
3/4 20 1.1 1.7 1.3 2.0
1 25 1.7 2.5 2.1 3.0
1 1/4 32 2.3 3.4 2.9 4.3
1 1/2 40 2.7 4.0 3.6 5.3
2 50 3.6 5.4 5.0 7.5
2 1/2 65 5.8 8.6 7.9 11.7
3 80 7.6 11.2 10.8 15.9
3 1/2 90 9.1 13.5 13.4 19.8
4 100 10.8 16.0 16.3 24.2
5 125 14.6 21.7 23.2 34.6
6 150 19.0 28.2 31.5 46.8
8 200 28.5 42.5 50.1 74.6
10 250 40.5 60.2 74.6 111
12 300 51.1 75.9 102 152
14 350 63.0 93.7 122 181
16 400 83.0 124 160 237
18 450 105 156 202 301
20 500 123 183 243 362
24 600 171 255 345 514
Weight of Insulation on Pipe
Weight of stone wool insulation mat on pipes.
Weight of Stone Wool Insulation Mat on Pipes
Nominal DiameterOutside Diameter
(mm)
Insulation Weight (kg/m pipe)
Insulation Thichness (mm)
(mm)(in)3040506080100120140
15 ½ 21.3 4 5 6 8 11 15 19 24
25 1 33.7 4 5 7 8 12 15 20 25
50 2 60.3 5 7 8 10 13 17 22 27
65 76.1 6 7 9 10 14 18 23 28
80 3 88.9 7 8 10 11 15 19 24 29
100 4 114.3 8 9 11 12 16 21 26 31
200 8 219.1 12 14 16 18 23 28 33 39
300 12 323.9 17 19 21 24 29 35 41 47
500 20 508.0 25 28 31 34 40 47 54 62
700 28 711.0 34 37 41 44 52 60 69 78
Dimensions of Pipes and Tubes
ANSI Steel Pipe Schedule 40 Chart: Dimensions, Weights & Specifications
Cement Lined Carbon Steel Pipes
Dimensions of cement lined carbon steel pipes.
Ice Loaded Pipelines
Ice coat weight on horizontal pipe lines.
Metals and Alloys - Densities
NPS (Nominal Pipe Size) Guide: Dimensions, Charts & Specifications
The size of pipes, fittings, flanges and valves are often given in inches as NPS - Nominal Pipe Size, or in metric units as DN - 'Diametre Nominal'.
Pipes - Nominal Wall Thickness
Nominal wall thickness of seamless and welded carbon and alloy steel pipes
Pipes with Water Content - Weight and Volume
Estimate water content in pipes - weight and volume.
Piping Equations
Calculate cross-sectional areas, weight of empty pipes, weight of pipes filled with water, inside and outside surface areas.
Schedule - Terminology
Introduction to the schedule terminology of pipes.
Steel Flats - Weights
Steel Pipes - Weight
Steel Plate Weight Guide: Calculator & Data Table
Welded Steel Pipes - Weights
Nominal weights of welded steel pipes ranging 26 - 60 inches.
