Steel Flats - Weights
The weight of a mild steel flat can be calculated as
W = 0.0075 w t (1)
W = weight (kg/m)
w = flat width (mm)
t = flat thickness (mm)
Flat Size (mm) | Weight (kg/m) |
13 x 3 | 0.31 |
13 x 6 | 0.61 |
16 x 3 | 0.38 |
20 x 3 | 0.47 |
20 x 5 | 0.79 |
20 x 6 | 0.94 |
20×10 | 1.57 |
25 x 3 | 0.59 |
25 x 5 | 0.98 |
25 x 6 | 1.18 |
25 x 8 | 1.57 |
25×10 | 1.96 |
25 x 12 | 2.36 |
30 x 3 | 0.71 |
30 x 5 | 1.18 |
30 x 6 | 1.41 |
30 x 8 | 1.88 |
30×10 | 2.36 |
30 x 12 | 2.83 |
30 x 20 | 4.71 |
35 x 6 | 1.65 |
35×10 | 2.75 |
35 x 12 | 3.30 |
35 x 20 | 5.50 |
40 x 3 | 0.94 |
40 x 5 | 1.57 |
40 x 6 | 1.88 |
40 x 8 | 2.51 |
40×10 | 3.14 |
40 x 12 | 3.77 |
40 x 15 | 4.71 |
40 x 20 | 6.28 |
40 x 25 | 7.85 |
40 x 30 | 9.42 |
45 x 3 | 1.06 |
45 x 6 | 2.12 |
45 x 8 | 2.83 |
45×10 | 3.53 |
45 x 12 | 4.24 |
45 x 15 | 5.29 |
45 x 20 | 7.07 |
45 x 25 | 8.83 |
50 x 3 | 1.18 |
50 x 5 | 1.96 |
50 x 6 | 2.36 |
50 x 8 | 3.14 |
50×10 | 3.93 |
50 x 12 | 4.71 |
50 x 15 | 5.98 |
50 x 20 | 7.85 |
50 x 25 | 9.81 |
50 x 30 | 11.80 |
50 x 40 | 15.70 |
American Standard Steel Channels: Weight, Dimensions & Properties
American Wide Flange Steel Beams (W-Beams) - Dimensions and Properties in Imperial Units
Dimensions, weight, section properties, and essential data of American wide flange steel beams (W-beams) according to the ASTM A6 standard.
Weight of round bars.
Mild Steel - Square Bars Weight
Typical weights of mild steel square bars.
Pipe Weight Calculator
Steel Angles - Equal Legs
Steel Pipes - Weight
Steel Plate Weight Guide: Calculator & Data Table
Steel Wool - Grades
Steel wool grades vs. fiber thickness.
Weight vs. Gauges Chart
Gauge and weight chart for sheet steel, galvanized steel, stainless steel, aluminum and strip & tubing.
