Weight vs. Gauges Chart
Wire gauge is a measure for the size of a wire, either in diameter or in cross sectional area.
Gauge and weight chart for sheet steel, galvanized steel, stainless steel, aluminum and strip & tubing:
For full table with Stainless Steel, Aluminum, Strip and Tubing - rotate the screen!
Weight vs. Gauges
GaugeUS Standard GaugeSheet SteelGalvanized SteelStainless SteelAluminumStrip & Tubing
(inches)
Gauge Decimal
(inches)
Weight
(lb/ft2)
Gauge Decimal
(inches)
Weight
(lb/ft2)
Gauge Decimal
(inches)
Weight
(lb/ft2)
Gauge Decimal
(inches)
Weight
(lb/ft2)
Gauge Decimal
(inches)
44 0.0047
43 0.0049
42 0.0051
41 0.0053
40 0.0055
39 0.0059
38 0.0063 0.0060 0.0062 0.0040
37 0.0066 0.0064 0.0066 0.0045
36 0.0070 0.0067 0.0070 0.0050 0.004
35 0.0078 0.0075 0.0078 0.0056 0.005
34 0.0086 0.0082 0.0086 0.0063 0.007
33 0.0094 0.0090 0.0094 0.0071 0.008
32 0.0102 0.0097 0.0102 0.0080 0.009
31 0.0109 0.0105 0.0109 0.0089 0.010
30 0.0125 0.0120 0.500 0.016 0.656 0.0125 0.0100 0.141 0.012
29 0.0141 0.0135 0.563 0.017 0.719 0.0141 0.0113 0.160 0.013
28 0.0156 0.0149 0.625 0.019 0.781 0.0156 0.0126 0.178 0.014
27 0.0172 0.0164 0.688 0.020 0.844 0.0172 0.0142 0.200 0.016
26 0.0188 0.0179 0.750 0.022 0.906 0.0187 0.756 0.0159 0.224 0.018
25 0.0219 0.0209 0.875 0.025 1.031 0.0219 0.0179 0.253 0.020
24 0.0250 0.0239 1.000 0.028 1.156 0.0250 1.008 0.0201 0.284 0.022
23 0.0281 0.0269 1.125 0.031 1.281 0.0281 0.0226 0.319 0.025
22 0.0313 0.0299 1.250 0.034 1.406 0.0312 1.26 0.0253 0.357 0.028
21 0.0344 0.0329 1.375 0.037 1.531 0.0344 0.0285 0.402 0.032
20 0.0375 0.0359 1.500 0.040 1.656 0.0375 1.512 0.0320 0.452 0.035
19 0.0438 0.0418 1.750 0.046 1.906 0.0437 0.0359 0.507 0.042
18 0.0500 0.0478 2.000 0.052 2.156 0.0500 2.016 0.0403 0.569 0.049
17 0.0563 0.0538 2.250 0.058 2.406 0.0562 0.0453 0.639 0.058
16 0.0625 0.0598 2.500 0.064 2.656 0.0625 2.52 0.0508 0.717 0.065
15 0.0703 0.0673 2.813 0.071 2.969 0.0703 0.0571 0.806 0.072
14 0.0781 0.0747 3.125 0.079 3.281 0.0781 3.15 0.0641 0.905 0.083
13 0.0938 0.0897 3.750 0.093 3.906 0.0937 0.0720 1.016 0.095
12 0.1094 0.1046 4.375 0.108 4.531 0.1094 4.41 0.0808 1.140 0.109
11 0.1250 0.1196 5.000 0.123 5.156 0.1250 5.04 0.0907 1.280 0.120
10 0.1406 0.1345 5.625 0.138 5.781 0.1406 5.67 0.1019 1.438 0.134
9 0.1563 0.1495 6.250 0.153 6.406 0.1562 0.1144 1.614 0.148
8 0.1719 0.1644 6.875 0.168 7.031 0.1719 6.93 0.1285 1.813 0.165
7 0.1875 0.1793 7.500 0.1875 7.871 0.1443 2.036 0.180
6 0.2031 0.1943 8.125 0.2031 0.1620 2.286 0.203
5 0.2188 0.2092 8.750 0.2187 0.1819 0.220
4 0.2344 0.2242 9.375 0.2344 0.2043 0.238
3 0.2500 0.2391 10.00 0.2500 0.2294 0.259
2 0.2656 0.2656 0.2576 0.284
1 0.2813 0.2812 0.2893 0.300
1/0
(0)
0.3125 0.3125 0.3249 0.340
2/0
(00)
0.3438 0.3437 0.3648 0.380
3/0
(000)
0.3750 0.3750 0.4096 0.425
4/0
(0000)
0.4063 0.4062 0.4600 0.454
5/0
(00000)
0.4375 0.4375 0.5165 0.500
6/0
(000000)
0.4688 0.4687 0.5800
7/0
(00000000)
0.5000
  • 1 ft2 = 0.0929 m2
  • 1 lb = 0.4536 kg
Miscellaneous
AWG - American Wire Gauge vs. Circular Mils
AWG vs. diameter mil, circular mil, diameter in mm and area in mm2.
AWG Wire Gauge Chart & Table – American Wire Gauge (AWG) Standards
The AWG (American Wire Gauge) wire size chart with detailed specifications on wire diameter, resistance, and ampacity. Find conversions between AWG sizes and metric units for electrical and engineering applications.
BWG - Birmingham Wire Gauge
Used to determine wall thickness of pipe - in gauge and decimal parts of inch.
Copper Wire - Electrical Resistance vs. Gauge
Gauge, weight, circular mils and electrical resistance in copper wire.
Mild Steel - Square Bars Weight
Typical weights of mild steel square bars.
Standard Gauges
Standard gauges for wire and sheet - American, Birmingham, Washburn, Music, Stubs ..
Steel Flats - Weights
Steel Plate Weight Guide: Calculator & Data Table
SWG - Standard Wire Gauge
Imperial Standard Wire Gauge used with wire and sheet metal.
Welded Steel Pipes - Weights
Nominal weights of welded steel pipes ranging 26 - 60 inches.
