Polymers - Specific Heats
Specific heat of some common polymers at 0 oC:
PolymerSpecific Heat
(J/(kg oC))
Epoxy resin, cured 1110
Nylon 6 1310
PET 1030
PMMA, Perspex 1270
Polycarbonate 1100
Polyethylene 1550
Polystyrene 1110
Rubber, natural - vulcanised or unvulvanised 1800
Polytetrafluoroethylene (PTFE) 970
PVC 880
  • 1 J/(kg oC) = 2.389×10-4 kcal/(kg oC) = 2.389×10-4 Btu/lbmoF
Material Properties
Fibre-reinforced Polymer Composites
Mechanical properties of fibers used to reinforce polymer composites.
Metals - Specific Heats
Thermal conductivity of plastics.
Polymers - Physical Properties
Densities, tensile strength, elongation, Youngs modulus and Brinell hardness.
Solids - Specific Heats
Specific Heat of Common Liquids and Fluids
Specific Heat of Common Materials – Engineering Reference
