Plastic | Thermal Conductivity (W/(m K)) |
Acrylic | 0.20 |
Epoxy | 0.17 |
Epoxy glass fibre | 0.23 |
Nylon 6 | 0.25 |
Polyethylene, low density (PEL) | 0.33 |
Polyethylene, high density (PEH) | 0.50 |
PTFE | 0.25 |
PVC | 0.19 |
Conductive Heat Transfer
Typical heat exchanger materials and their thermal conductivities.
Online calculator, figures and tables showing thermal conductivity of nitrogen, N2, at varying temperarure and pressure, SI and Imperial units.
Plastics - Abbreviations
Commonly used plastic abbreviations.
Plastics - Recycling Codes and Labeling
Symbol codes and labeling used for recycling plastic products like bottles, containers and packagin.
Polymers - Physical Properties
Densities, tensile strength, elongation, Youngs modulus and Brinell hardness.
Polymers - Specific Heats
Specific heat of polymers like epoxy, PET, polycarbonate and more.
Thermal Conductivity of Common Materials - Solids, Liquids and Gases
Thermal conductivity of various common materials, including metals, gases, and building materials. Essential data for engineers, architects, and designers working with heat transfer and insulation.
