Thermal Conductivity indicates a materials ability to conduct heat.
The calculator below can be used to convert between common units for thermal conductivity:
• Thermodynamics
Online calculator, figures and table showing thermal conductivity of carbon dioxide, CO2, at temperatures ranging from -50 to 775 °C (-50 to 1400 °F) at atmospheric and higher pressure - Imperial and SI Units.
Conductive Heat Transfer
Typical heat exchanger materials and their thermal conductivities.
Overall Heat Transfer Coefficient: Definitions, Values & Applications
Thermal conductivity of plastics.
Thermal Conductivity of Common Materials - Solids, Liquids and Gases
Thermal conductivity of various common materials, including metals, gases, and building materials. Essential data for engineers, architects, and designers working with heat transfer and insulation.
Thermal Conductivity Units Converter
Unit Factor Method
