Specific Heat of Common Liquids and Fluids
The specific heat for some commonly used liquids and fluids is given in the table below.
For conversion of units, use the Specific heat online unit converter.
See also tabulated values of specific heat of gases, food and foodstuff, metals and semimetals, common solids and other common substances as well as values of molar specific heat of common organic substances and inorganic substances.
Product | Specific Heat - cp - | |
(kJ/kgK) | (Btu/(lb oF)) (Kcal/kg oC) | |
Acetic acid | 2.043 | 0.49 |
Acetone | 2.15 | 0.51 |
Alcohol, ethyl 31 oF (ethanol) | 2.3 | 0.548 |
Alcohol, ethyl 104 oF (ethanol) | 2.72 | 0.65 |
Alcohol, methyl. 40 - 50 oF | 2.47 | 0.59 |
Alcohol, methyl. 60 - 70 oF | 2.51 | 0.6 |
Alcohol, propyl | 2.37 | 0.57 |
Ammonia, 31 oF | 4.6 | 1.1 |
Ammonia, 104 oF | 4.86 | 1.16 |
Ammonia, 176 oF | 5.4 | 1.29 |
Ammonia, 211 oF | 6.2 | 1.48 |
Ammonia, 238 oF | 6.74 | 1.61 |
Aniline | 2.18 | 0.514 |
Antifreeze mixtures (solutions) | ||
Asphalt, liquid | 2.09 | 0.5 |
Benzene, 60 oF | 1.8 | 0.43 |
Benzene, 150 oF | 1.92 | 0.46 |
Benzine | 2.1 | |
Benzol | 1.8 | 0.43 |
Bismuth, 800 oF | 0.15 | 0.0345 |
Bismuth, 1000 oF | 0.155 | 0.0369 |
Bismuth, 1400 oF | 0.165 | 0.0393 |
Bromine | 0.47 | 0.11 |
n-Butane, 31 oF | 2.3 | 0.55 |
Calcium Chloride | 3.06 | 0.73 |
Carbon Disulfide | 0.992 | 0.237 |
Carbon Tetrachloride | 0.866 | 0.207 |
Castor Oil | 1.8 | 0.43 |
Chloroform | 1.05 | 0.251 |
Citron Oil | 1.84 | 0.44 |
Decane | 2.21 | 0.528 |
Diesel fuel | 2.05 | |
Diphenylamine | 1.93 | 0.46 |
Dodecane | 2.21 | 0.528 |
Dowtherm | 1.55 | 0.37 |
Ethanol | 2.43 | |
Ethanol 95% | 2.43 | |
Ether | 2.21 | 0.528 |
Ethyl chloride | 1.54 | |
Ethyl ether | 2.22 | 0.529 |
Ethylene glycol | 2.36 | 0.56 |
Dichlorodifluoromethane R-12 saturated -40 oF | 0.88 | 0.211 |
Dichlorodifluoromethane R-12 saturated 0 oF | 0.91 | 0.217 |
Dichlorodifluoromethane R-12 saturated 120 oF | 1.02 | 0.244 |
Fuel Oil min. | 1.67 | 0.4 |
Fuel Oil max. | 2.09 | 0.5 |
Gasoline, petrol | 2.22 | 0.53 |
Glycerine | 2.43 | 0.576 |
Heptane | 2.24 | 0.535 |
Hexane | 2.26 | 0.54 |
Hydrochlor acid | 3.14 | |
Iodine | 2.15 | 0.51 |
Kerosene | 2.01 | 0.48 |
Linseed Oil | 1.84 | 0.44 |
Light Oil, 60 oF | 1.8 | 0.43 |
Light Oil, 300 oF | 2.3 | 0.54 |
Lubricating oil | 2.09 | |
Mercury | 0.14 | 0.03 |
Methanol | 2.51 | |
Methyl alcohol | 2.51 | |
Milk | 3.93 | 0.94 |
Naphthalene | 1.72 | 0.41 |
Nitric acid | 1.72 | |
Nitro benzole | 1.52 | 0.362 |
Octane | 2.15 | 0.51 |
Oil, Castor | 1.97 | 0.47 |
Oil, Olive | 1.97 | 0.47 |
Oil, mineral | 1.67 | 0.4 |
Oil, turpentine | 1.8 | |
Oil, vegetable | 1.67 | 0.4 |
Olive oil | 1.97 | 0.47 |
Paraffin | 2.13 | 0.51 |
Perchlor ethylene | 0.905 | |
Petroleum | 2.13 | 0.51 |
Petroleum ether | 1.76 | |
Phenol | 1.43 | 0.34 |
Potassium hydrate | 3.68 | 0.88 |
Propane, 31 oF | 2.4 | 0.576 |
Propylene | 2.85 | 0.68 |
Propylene Glycol | 2.5 | 0.60 |
Rapeseed oil | 1.97 | |
Salt solution 20% | 3.43 | |
Sesame oil | 1.63 | 0.39 |
Silicone oil | 1.09 | |
Sodium, 200 oF | 1.38 | 0.33 |
Sodium, 1000 oF | 1.26 | 0.3 |
Sodium hydrate | 3.93 | 0.94 |
Soya bean oil | 1.97 | 0.47 |
Sulfuric acid concentrated | 1.38 | |
Sulfuric acid | 1.34 | |
Tar | 1.56 | |
Toluene | 1.72 | 0.41 |
Transformer oil | 1.88 | |
Trichlor ethylene | 1.30 | |
Tuluol | 1.51 | 0.36 |
Turpentine oil | 1.72 | 0.411 |
Water, fresh | 4.19 | 1 |
Water, sea 36 oF | 3.93 | 0.938 |
Xylene | 1.72 | 0.41 |
- 1 kJ/kgK = 1000 J/(kgoC) = 0.2389 kcal/(kg oC) = 0.2389 Btu/lbmoF
- T (oC) = 5/9 (T (oF) - 32)
See also tabulated values of specific heat of Gases, Food and foodstuff, Metals and semimetals, Common solids and other Common substances.
Heating Energy
The energy required to heat a product can be calculated as
q = cp m dt (1)
q = heat required (kJ)
cp = specific heat (kJ/kg K, kJ/kg oC)
dt = temperature difference (K, oC)
Example - Required Heat to increase Temperature i Water
10 kg of water is heated from 20 oC to 100 oC - a temperature difference 80 oC (K). The heat required can be calculated as
q = (4.19 kJ/kg K) (10 kg) (80 oC)
= 3352 kJ
• Thermodynamics
Electric Heating of Mass
Electric heating and temperature change vs. energy supplied.
Food and Foodstuff - Specific Heat
Specific heat of common food and foodstuff like apples, bass, beef, pork and many more.
Gases - Specific Heat and Individual Gas Constants
Gasoline - Density, Specific Heat, Viscosity and Thermal Conductivity vs. Temperature
Heat Capacity
Heating Up Applications - Energy Required and Heat Transfer Rates
Energy required to heat up a substance.
Light Oil Suction - Flow Velocities
Recommended max. suction flow velocities when pumping light oils.
Liquid Densities
Mixing Fluids
Final mass and temperature when mixing fluids.
Mixing Liquids and/or Solids - Final Temperatures
Calculate the final temperature when liquids or solids are mixed
Oil Tanks - Heat Loss
Heat loss from lagged and unlagged, sheltered and exposed oil tanks.
Pipes Submerged in Oil or Fat - Heat Emission
Heat emission from steam or water heating pipes submerged in oil or fat - forced and natural circulation.
Polymers - Specific Heats
Specific heat of polymers like epoxy, PET, polycarbonate and more.
Solids - Specific Heats
Storing Thermal Heat
Energy stored as sensible heat in different types of materials.
Sulfuric Acid - Density
Density of sulfuric acid at various temperatures and concentrations.
