Specific Heat is the amount of heat required to change one mass unit of a substance by one degree in temperature.
Specific Heat Converter
The calculator below can be used to convert between some common specific heat units
Use the links to see tabulated values of specific heat of gases, common liquids and fluids, food and foodstuff, metals and semimetals, common solids and other common substances.
Specific Heat Converting Chart
Use of the chart is illustrated below.
1000 J/kg oC equals to 1 kJ/kg oC or 0.239 Btu/lb oF.
• Basics
• Thermodynamics
Air - Specific Heat Ratio
Specific Heat Ratio of air at temperatures ranging -40 - 1000 degC (-40 - 1500 degF) at standard atmospheric pressure - Imperial and SI Units.
Carbon Dioxide - Specific Heat of Gas vs. Temperature
Specific heat of Carbon Dioxide gas - CO2 - temperatures ranging 175 - 6000 K.
Food and Foodstuff - Specific Heat
Specific heat of common food and foodstuff like apples, bass, beef, pork and many more.
Gases - Molar Specific Heats
Molar specific heats for some common gases at constant volume.
Gases - Specific Heat and Individual Gas Constants
Heat, Work and Energy
Heat vs. work vs. energy.
Human Body - Specific Heat
Specific heat of the human body - compared to substances like protein and wood.
Metals - Specific Heats
Mixing Fluids
Final mass and temperature when mixing fluids.
Polymers - Specific Heats
Specific heat of polymers like epoxy, PET, polycarbonate and more.
Solids - Specific Heats
Specific Heat Capacity of Air: Isobaric and Isochoric Heat Capacities at Various Temperatures and Pressures
Online calculator with figures and tables showing specific heat (Cp and Cv) of dry air vs. temperature and pressure. SI and imperial units.
Specific Heat of Common Liquids and Fluids
Specific Heat of Common Materials – Engineering Reference
Storing Thermal Heat
Energy stored as sensible heat in different types of materials.
Unit Factor Method
Water Vapor - Specific Heat vs. Temperature
Specific heat of Water Vapor - H2O - at temperatures ranging 175 - 6000 K.
