Air - Specific Heat Ratio
Specific Heat Ratio of Air at Standard Atmospheric Pressure in Imperial (BG) Units:
Temperature - t - (oF) | Specific Heat Ratio k = cp / cv |
-40 | 1.401 |
-20 | 1.401 |
0 | 1.401 |
10 | 1.401 |
20 | 1.401 |
30 | 1.401 |
40 | 1.401 |
50 | 1.401 |
60 | 1.401 |
70 | 1.401 |
80 | 1.400 |
90 | 1.400 |
100 | 1.400 |
120 | 1.400 |
140 | 1.399 |
160 | 1.399 |
180 | 1.399 |
200 | 1.398 |
300 | 1.394 |
400 | 1.389 |
500 | 1.383 |
750 | 1.367 |
1000 | 1.351 |
1500 | 1.329 |
- cp = specific heat - constant pressure
- cv = specific heat - constant volume
Specific Heat Ratio of Air at Standard Atmospheric Pressure in SI Units:
Temperature - t - (oC) | Specific Heat Ratio k = cp / cv |
-40 | 1.401 |
-20 | 1.401 |
0 | 1.401 |
5 | 1.401 |
10 | 1.401 |
15 | 1.401 |
20 | 1.401 |
25 | 1.401 |
30 | 1.400 |
40 | 1.400 |
50 | 1.400 |
60 | 1.399 |
70 | 1.399 |
80 | 1.399 |
90 | 1.398 |
100 | 1.397 |
200 | 1.390 |
300 | 1.379 |
400 | 1.368 |
500 | 1.357 |
1000 | 1.321 |
• Gases and Compressed Air
Gases - Specific Heat and Individual Gas Constants
Specific Heat Capacity of Air: Isobaric and Isochoric Heat Capacities at Various Temperatures and Pressures
Online calculator with figures and tables showing specific heat (Cp and Cv) of dry air vs. temperature and pressure. SI and imperial units.
