Solids - Specific Heats
The specific heat of some commonly used solids is given in the table below.
For conversion of units, use the Specific heat online unit converter.
See also tabulated values of specific heat of gases, food and foodstuff, metals and semimetals, common liquids and fluids and other common substances as well as values of molar heat capacity of common organic substances and inorganic substances.
Product | Specific Heat - cp- | |
(Btu/(lbm oF)) (kcal/(kg oC)) | (kJ/kgK) | |
Agate | 0.19 | 0.80 |
Aluminum bronze | 0.10 | 0.44 |
Aluminum, 0 oC | 0.21 | 0.87 |
Antimony | 0.05 | 0.21 |
Apatite | 0.2 | 0.84 |
Arsenic | 0.083 | 0.35 |
Artificial wool | 0.32 | 1.36 |
Asbestos cement board | 0.2 | 0.84 |
Asbestos mill board | 0.2 | 0.84 |
Ashes | 0.2 | 0.84 |
Asphalt concrete (with aggregate) | 0.22 | 0.92 |
Augite | 0.19 | 0.80 |
Bakelite. wood filler | 0.33 | 1.38 |
Bakelite. asbestos filler | 0.38 | 1.59 |
Barite | 0.11 | 0.46 |
Barium | 0.07 | 0.29 |
Basalt rock | 0.2 | 0.84 |
Beef tallow | 0.87 | |
Beeswax | 0.82 | 3.40 |
Beryl | 0.2 | 0.84 |
Beryllium | 0.24 | 1.02 |
Bismuth | 0.03 | 0.13 |
Boiler scale | 0.19 | 0.80 |
Bone | 0.11 | 0.44 |
Borax | 0.24 | 1.0 |
Boron | 0.31 | 1.3 |
Brass | 0.09 | 0.38 |
Brick, common | 0.22 | 0.9 |
Brick, hard | 0.24 | 1 |
Bronze, phosphor | 0.09 | 0.38 |
Cadmium | 0.06 | 0.25 |
Calcite 32 - 100F | 0.19 | 0.8 |
Calcite 32 - 212F | 0.2 | 0.84 |
Calcium | 0.15 | 0.63 |
Calcium carbonat | 0.18 | 0.76 |
Calcium sulfate | 0.27 | 1.1 |
Carbon, Diamond | 0.12 | 0.52 |
Carbon, Graphite | 0.17 | 0.71 |
Carborundum | 0.16 | 0.67 |
Cassiterite | 0.09 | 0.38 |
Cement dry | 0.37 | 1.55 |
Cement powder | 0.2 | 0.84 |
Cellulose | 0.37 | 1.6 |
Celluloid | 0.36 | 1.5 |
Charcoal | 0.24 | 1 |
Chalk | 0.22 | 0.9 |
Chalcopyrite | 0.13 | 0.54 |
Chamotte fireclay | 0.8 | |
Charcoal, wood | 0.24 | 1 |
Chromium | 0.12 | 0.5 |
Clay | 0.22 | 0.92 |
Coal, anthracite | 0.3 | 1.26 |
Coal, bituminous | 0.33 | 1.38 |
Cobalt | 0.11 | 0.46 |
Coke | 0.2 | 0.85 |
Concrete, stone | 0.18 | 0.75 |
Concrete, light | 0.23 | 0.96 |
Constantan | 0.098 | 0.41 |
Copper | 0.09 | 0.39 |
Cork, corkboard | 0.45 | 1.9 |
Corundum | 0.1 | 0.42 |
Cotton | 0.32 | 1.34 |
Diamond | 0.15 | 0.63 |
Dolomite rock | 0.22 | 0.92 |
Duralium | 0.22 | 0.92 |
Earth, dry | 0.3 | 1.26 |
Electron | 0.24 | 1.00 |
Emery | 0.23 | 0.96 |
Fats | 0.46 | 1.93 |
Fiberboard, light | 0.6 | 2.5 |
Fiber hardboard | 0.5 | 2.1 |
Fire brick | 0.25 | 1.05 |
Fluorite | 0.22 | 0.92 |
Fluorspar | 0.21 | 0.88 |
Galena | 0.05 | 0.21 |
Garnet | 0.18 | 0.75 |
Germanium | 0.31 | |
Glass | 0.2 | 0.84 |
Glass, crystal | 0.12 | 0.5 |
Glass, plate | 0.12 | 0.5 |
Glass, Pyrex | 0.18 | 0.75 |
Glass, window | 0.2 | 0.84 |
Glass-wool | 0.16 | 0.67 |
Gold | 0.03 | 0.13 |
Granite | 0.19 | 0.79 |
Gypsum | 0.26 | 1.09 |
Hairfelt | 0.5 | 2.1 |
Heat conductive alloy NiCr 8020 | 0.5 | |
Hermatite | 0.16 | 0.67 |
Hornblende | 0.2 | 0.84 |
Hypersthene | 0.19 | 0.8 |
Ice -111 oF | 0.35 | 1.47 |
Ice -40 oF | 0.43 | 1.8 |
Ice -4 oF | 0.47 | 1.97 |
Ice 31 oF (0 oC) | 0.49 | 2.09 |
India rubber min | 0.27 | 1.13 |
India rubber max | 0.98 | 4.1 |
Indium | 0.24 | |
Ingot iron | 0.12 | 0.49 |
Iodine | 0.052 | 0.218 |
Iridium | 0.03 | 0.13 |
Iron, 20 oC | 0.11 | 0.46 |
Labradorite | 0.19 | 0.8 |
Lava | 0.2 | 0.84 |
Limestone | 0.217 | 0.91 |
Litharge | 0.21 | 0.88 |
Lead | 0.03 | 0.13 |
Leather, dry | 0.36 | 1.5 |
Lithium | 0.86 | 3.58 |
Magnetite | 0.16 | 0.67 |
Malachite | 0.18 | 0.75 |
Manganese | 0.11 | 0.46 |
Magnesia (85%) | 0.2 | 0.84 |
Magnesium | 0.25 | 1.05 |
Marble, mica | 0.21 | 0.88 |
Mercury | 0.03 | 0.14 |
Mica | 0.12 | 0.5 |
Mineral wool blanket | 0.2 | 0.84 |
Molybdenum | 0.065 | 0.27 |
Nickel | 0.11 | 0.46 |
Oliglocose | 0.21 | 0.88 |
Orthoclose | 0.19 | 0.8 |
Osmium | 0.03 | 0.13 |
Oxide of chrome | 0.18 | 0.75 |
Palladium | 0.24 | |
Paper | 0.33 | 1.34 |
Paraffin wax | 0.7 | 2.9 |
Peat | 0.45 | 1.88 |
Phosphorbronze | 0.086 | 0.36 |
Phosphorus | 0.19 | 0.80 |
Pig iron, white | 0.13 | 0.54 |
Pinchbeck | 0.09 | 0.38 |
Pit coal | 0.24 | 1.02 |
Plaster, light | 0.24 | 1 |
Plaster, sand | 0.22 | 0.9 |
Plastics, foam | 0.3 | 1.3 |
Plastics, solid | 0.4 | 1.67 |
Platinum, 0 oC | 0.032 | 0.13 |
Plutonium | 0.14 | |
Polycarbonate | 1.17 | |
Polyethylene | 2.1 | |
Polystyrene | 1.3 | |
Porcelain | 0.26 | 1.07 |
Potassium | 0.13 | 0.54 |
Pyrex glass | 0.2 | 0.84 |
Pyrolusite | 0.16 | 0.67 |
Pyroxylin plastics | 0.36 | 1.51 |
Quartz mineral 55 - 211 oF | 0.19 | 0.8 |
Quartz mineral 31 oF (0 oC) | 0.17 | 0.71 |
Red lead | 0.022 | 0.09 |
Red metal | 0.09 | 0.38 |
Rhenium | 0.033 | 0.14 |
Rhodium | 0.057 | 0.24 |
Rock salt | 0.22 | 0.92 |
Rosin | 0.31 | 1.30 |
Rubber | 0.48 | 2.01 |
Rubidium | 0.079 | 0.33 |
Salt | 0.21 | 0.88 |
Sand, dry | 0.19 | 0.80 |
Sandstone | 0.22 | 0.92 |
Sawdust | 0.21 | 0.9 |
Selenium | 0.078 | 0.33 |
Serpentine | 0.26 | 1.09 |
Silica aerogel | 0.2 | 0.84 |
Silicon | 0.18 | 0.75 |
Silicon carbide | 0.16 | 0.67 |
Silk | 0.33 | 1.38 |
Silver, 20 oC | 0.056 | 0.23 |
Slate | 0.18 | 0.76 |
Sodium | 0.3 | 1.26 |
Soil, dry | 0.19 | 0.80 |
Soil, wet | 0.35 | 1.48 |
Soot | 0.84 | |
Steatite | 0.2 | 0.83 |
Steel | 0.12 | 0.49 |
Stone | 0.2 | 0.84 |
Stoneware | 0.19 | 0.8 |
Sulphur | 0.17 | 0.71 |
Tantalium | 0.033 | 0.14 |
Tar | 0.35 | 1.47 |
Tellurium | 0.05 | 0.21 |
Thorium | 0.033 | 0.14 |
Tile hollow | 0.15 | 0.63 |
Timber, see wood | ||
Tin | 0.057 | 0.24 |
Titanium | 0.11 | 0.47 |
Topaz | 0.21 | 0.88 |
Tungsten | 0.03 | 0.134 |
Uranium | 0.028 | 0.12 |
Vanadium | 0.12 | 0.5 |
Vermiculite | 0.2 | 0.84 |
Vulcanite | 0.33 | 1.38 |
Wax | 0.82 | 3.43 |
Welding iron | 0.12 | 0.52 |
White metal | 0.035 | 0.15 |
Wood, balsa | 0.7 | 2.9 |
Wood, oak | 0.48 | 2 |
Wood, white pine | 0.6 | 2.5 |
Wool, loose | 0.3 | 1.26 |
Wool, felt | 0.33 | 1.38 |
Zinc | 0.09 | 0.38 |
Zirconium | 0.28 |
- 1 Btu/lbmoF = 4.187 kJ/kg K = 1 kcal/kgoC
- T (oC) = 5/9(T (oF) - 32)
- T (oF) = (T (oC))(9/5) + 32
Heating Energy
The energy required to heat a product can be calculated as
q = cp m dt (1)
q = heat required (kJ)
cp = specific heat (kJ/kg K, kJ/kg oC)
dt = temperature difference (K, oC)
Example - Required Heat to increase the Temperature in a Piece of Oak
If 10 kg of oak is heated from 20 oC to 50 oC - a temperature difference 30 oC (K), the heat required can be calculated as
q = (2 kJ/kg K) (10 kg) (30 oC)
= 600 kJ
If one hour (3600 s) is used to heat the oak - the power required can be calculated with the equation
P = q / t (2)
P = power (kJ/s, kW)
t = time (s)
With values:
P = (600 kJ) / (3600 s)
= 0.17 kW
• Thermodynamics
Brick Densities
Densities of common types of bricks.
Ceramic Materials - Properties
Physical properties of ceramics.
Electric Heating of Mass
Electric heating and temperature change vs. energy supplied.
Food and Foodstuff - Specific Heat
Specific heat of common food and foodstuff like apples, bass, beef, pork and many more.
Gases - Specific Heat and Individual Gas Constants
Heat Capacity
Ice - Thermal Properties
Thermal and thermodynamic properties of ice like density, thermal conductivity and specific heat at temperatures from 0 to -100 oC.
Metals - Specific Heats
Minerals - Densities
Densities of minerals.
Minerals and other Materials - Specific Gravities
Specific gravities for minerals and other materials.
Mixing Fluids
Final mass and temperature when mixing fluids.
Mortar Types
ASTM mortar types.
Plastics - Abbreviations
Commonly used plastic abbreviations.
Polymers - Specific Heats
Specific heat of polymers like epoxy, PET, polycarbonate and more.
Solids - Melting and Boiling Temperatures
Melting and boiling temperatures of some products.
Specific Heat of Common Liquids and Fluids
Standard Grade Coal - Heat Values
Standard grades coal heat values.
Stone Masonry - Strength
Typical strength of stone masonry constructions.
Stones - Weight and Strength
Weight and strength of sandstone, granite, limestone, marble and slate.
Storing Thermal Heat
Energy stored as sensible heat in different types of materials.
