The maximum and minimum length of a pipe depends to the maximum and minimum temperature of the pipe - in cold (non operating) and running (operating) condition. The temperature expansion coefficient steel pipes per degree change of temperature is nearly constant:
- 6.5×10-6 (in/in oF)
- 14.0×10-6 (m/m oC)
Carbon Steel Pipes - Temperature Expansion - Fahrenheit
The temperature expansion of carbon steel pipes expressed in inches per 100 feet per degree Fahrenheit:
Carbon Steel Pipes - Temperature Expansion - Celcius
The temperature expansion of carbon steel pipes expressed in mm per m per degree Celsius:
Example - Expansion of Steam Pipe
The expansion of 10 m steam pipe from an installation temperature of 20 oC to design temperature 180 oC (pressure 10 bar) is 2.4 mm/m or
10 (m) 2.4 (mm/m) = 24 mm
• Piping Systems
• Temperature Expansion
Calculate ring (or pipe) diameter expansion or contraction when temperature changes.
Linear Thermal Expansion Coefficients of Materials
Linear thermal expansion coefficients of common materials, including metals, plastics, and composites.
Linear Thermal Expansion: Formula, Coefficients & Calculator
Piping Materials - Temperature Heat Expansion and Cooling Contraction
Expansion and contraction when cast iron, carbon and carbon molybdenum steel, wrought iron, copper, brass and aluminum pipes are heated or cooled.
Shrink-Fits Assembly
Assembly temperatures for shrink-fits.
Specific Heat of Common Liquids and Fluids
Specific Heat of Common Materials – Engineering Reference
Steam Pipes - Thermal Expansion
Thermal expansion of steam pipes heated from room temperature to operation temperature (mm pr. 100 m pipe).
Steel Pipes - Bundling Schedules Length and Weight
Bundling schedules for standard weight and extra strong steel pipes.
Steel Pipes - Weight
Steel Pipes Expansion Loops - Design and Calculation
Steel pipe expansion loops and their importance in managing thermal expansion, and how to design and size them effectively. Key considerations, calculations, and installation tips to prevent stress and damage in piping systems.
Thermal Expansion of Steam Pipes - (inches)
Expansion of steam pipes heated from room temperature to operation temperature.
