Linear Thermal Expansion: Formula, Coefficients & Calculator
When an object is heated or cooled, its length changes by an amount proportional to the original length and the change in temperature. The linear thermal expansion - the change in length - of an object can be expressed as
dl = L0 α (t1 - t0) (1)
dl = change in object length (m, inches)
L0 = initial length of object (m, inches)
α = linear expansion coefficient (m/moC, in/inoF)
t0 = initial temperature ( oC, oF)
t1 = final temperature ( oC, oF)
The final length of the object can be calculated as
L1 = L0 + dl
= L0 + L0 α (t1 - t0) (2)
L1 = final length of object (m, inches)
Note! - linear expansion coefficients for most materials varies with temperature .
Example - Expansion of Copper, Carbon and Stainless Steel Pipes
For wider temperature ranges - calculate for smaller spans and integrate the results.
Online Thermal Linear Expansion Calculator
Linear Temperature Coefficients - α - for some common metals
- aluminum : 0.000023 (m/moC) (23 μm/moC)
- steel: 0.000012 (m/moC) (12 μm/moC)
- copper: 0.000017 (m/moC) (17 μm/moC)
- more coefficients ..
- more metals ..
Example - Expansion of an Aluminum Beam
An aluminum construction is designed for temperatures ranging -30 oC to 50 oC . If a beam's length is 6 m when assembled at 20 oC - the shortest final length of the beam at minimum temperature -30 oC can be calculated as
L1 = (6 m) + (6 m) (0.000023 m/moC) ((-30 oC) - (20 oC))
= 5.993 m
The longest final length of the beam at maximum temperature 50 oC can be calculated as
L1 = (6 m) + (6 m) (0.000023 m/moC) ((50 oC) - (20 oC))
= 6.004 m
Superficial Expansion
The amount by which a unit area of a material increases when the temperature is raised by one degree is called the coefficient of superficial (area) expansion .
Cubic Expansion
The amount by which a unit volume of a material increases when the temperature is raised by one degree is called the coefficient of cubic expansion .
• Temperature Expansion
• Thermodynamics
Bimetallic Strips
Heat and bending of bimetallic strips.
Calculate ring (or pipe) diameter expansion or contraction when temperature changes.
Linear Thermal Expansion Coefficients of Materials
Linear thermal expansion coefficients of common materials, including metals, plastics, and composites.
Piping Materials - Temperature Heat Expansion and Cooling Contraction
Expansion and contraction when cast iron, carbon and carbon molybdenum steel, wrought iron, copper, brass and aluminum pipes are heated or cooled.
Shrink-Fits Assembly
Assembly temperatures for shrink-fits.
Solids - Volume Temperature Expansion Coefficients
Cubical expansion coefficients for solids.
Steam Pipes - Thermal Expansion
Thermal expansion of steam pipes heated from room temperature to operation temperature (mm pr. 100 m pipe).
Steel Pipes Expansion Loops - Design and Calculation
Steel pipe expansion loops and their importance in managing thermal expansion, and how to design and size them effectively. Key considerations, calculations, and installation tips to prevent stress and damage in piping systems.
Thermal Expansion - Superficial i.e. Area
Superficial i.e area temperature expansion - online calculator.
Thermal Expansion of Steam Pipes - (inches)
Expansion of steam pipes heated from room temperature to operation temperature.
