Radiation - Surface Emissivity Coefficients
The emissivity coefficient - ε - indicates the radiation of heat from a body according the Stefan-Boltzmann Law, compared with the radiation of heat from a ideal black body where the emissivity coefficient ε = 1.
Emissivity coefficients - ε - for some common material surfaces:
Material | Emissivity Coefficient - ε - |
Water (0 - 100 oC) | 0.95 - 0.963 |
Ice | 0.96 - 0.99 |
Snow | 0.96 - 0.98 |
Sand | 0.9 |
Granite | 0.96 |
Green Grass | 0.975 - 0.986 |
• Heat Loss and Insulation
• Insulation
• Insulation and Heat Loss from Steam and Condesate Pipe Lines
Heat loss from uninsulated and insulated steam and condensate pipes and tanks. Calculate insulation thicknesses.
• Thermodynamics
Absorbed Solar Radiation
Solar radiation absorbed by various materials.
Emissivity Coefficients of Common Materials: Data & Reference Guide
Overall Heat Transfer Coefficient: Definitions, Values & Applications
Pipes - Bare Surface Heat Loss
Heat loss vs. surface temperature.
Radiation Heat Transfer
Solar Heat Transmission through Windows
Solar heat gain through windows with roller shades, vertical blinds and Venetian blinds
Solar Radiation - Daily Surface Energy
Daily surface energy from solar radiation.
Surface Radiation Absorptivity
Radiation surface absorptivity.
