The moisture holding capacity of air increases dramatically with increased temperature as indicated in the diagrams below.
Air Moisture Holding Capacity - SI Units
Moisture holding capacity of air - kg water per kg dry air:
Air Moisture Holding Capacity - Imperial Units
Moisture holding capacity of air - lb water per lb dry air:
Moisture holding capacity of air - lb water per 1000 cubic feet dry air:
Note - the moisture holding capacity of air at 100 oF (38 oC) is 10 times the moisture holding capacity of air at 30 oF (~ 0 oC). This is a very important observation - especially when working with drying processes where air is used to transport moisture away from process and products.
In general
  • it is in general good energy economy to increase the air temperature in a dryer as much as possible! - the increased moisture transport capacity of air at higher temperature out-weights the increased energy-consumption for heating the dry air to higher temperature!
Air Psychrometrics
Steam and Condensate
Thermodynamics
Air - Drying Force
The drying force of air depends on the air moisture holding capacity and the water surface to air evaporation capacity.
Using steam to humidify air.
Air - Humidity Ratio
Air - Prandtl Number
Air and Steam Mixtures
Air in the steam will lower the surface temperatures in heat exchangers - and less heat will be transferred.
Air Conditioning - Cooling of Air and Condensate Generated
Water may condensate when air is cooled in air conditioning systems.
Air Properties: Temperature, Pressure & Density Data
Cooling Tower Efficiency
Maximum cooling tower efficiency is limited by the cooling air wet-bulb temperature.
Dehumidification - Removing Moisture from Air
Dehumidifying by cooling, adsorption or absorption.
Dry Air Thermodynamic and Physical Properties – Density, Specific Heat, Viscosity
THe essential thermodynamic properties of dry air like specific heat, ratio of specific heats, dynamic viscosity, thermal conductivity, Prandtl number, density and kinematic viscosity at temperatures ranging 175 - 1900 K.
Dry Bulb, Wet Bulb and Dew Point Temperatures
Dry Bulb, Wet Bulb and Dew Point temperatures can be used to determine the state of humid air.
Evaporation of water from a water surface - like a swimming pool or an open tank - depends on water temperature, air temperature, air humidity and air velocity above the water surface - online calculator.
Humid Air and the Ideal Gas Law
Pressure, temperature and volume in a perfect ideal gas like moist air (air with water vapor).
Mixing of Humid Air
Moist Air - Cooling and Dehumidifying
Cooling and dehumidifying processes of moist and humid air - sensible and latent cooling.
Moist Air - Degree of Saturation
Humidity ratio of moist air to humidity ratio of saturated moist air.
Moist Air - Partial Pressure and Daltons Law
The pressure in a mixture of dry air and water vapor - humid or moist air - can be estimated by using Daltons Law of partial pressures.
Moist Air - Properties
Psychrometric table with humid air properties like saturation pressure, specific volume, enthalpy and entropy.
Moist Air - Psychrometric Table for Pressure 29.92 inHg
Dry and wet bulb temperatures, saturation pressure, water vapor weight, specific volume, heat and more.
Moist Air - Relative Humidity
Relative humidity in moist air is the ratio of partial vapor pressure to air pressure.
Moist Air - Specific Volume
Specific volume of moist air is defined as the total volume of humid air per mass unit of dry air
Moist Air - Water Vapor and Saturation Pressure
Saturation pressure of water vapor in moist air vs. temperature.
Moist Air - Weight of Water Vapor
Weight of water vapor in air
Moisture Content Calculation
Calculate the moisture content in products like wood on wet and dry basis.
Removing Heat with Air
Calculating heat removed with air by measuring the wet bulb temperature.
