Moist Air - Water Vapor and Saturation Pressure
Water vapor is almost always present in the surrounding air.
Note! - the equations below is for pure water vapor - not moist air.
Saturation Pressure of Water Vapor
The maximum saturation pressure of the water vapor in moist air varies with the temperature of the air vapor mixture and can be expressed as:
pws = e(77.3450 + 0.0057 T - 7235 / T)/ T8.2                                 (1)
pws = water vapor saturation pressure (Pa)
e = the constant 2.718.......
T = dry bulb temperature of the moist air (K)
Density of Water Vapor
The density of water vapor can be expressed as:
ρw = 0.0022 pw / T                        (2)
p w = partial pressure water vapor (Pa, N/m2)
ρ w = density water vapor (kg/m3)
T = absolute dry bulb temperature (K)
Saturation pressure and density of water vapor for common temperatures
Moist Air - Saturation Pressure and Density vs. Temperature
TemperatureSaturation PressureDensity
(oC)(oF)(Pa)(mmHg)(psia)(inHg)(kg/m3)10-3
(lb/ft3)
0 32 603 4.6 0.09 0.18 0.005 0.30
10 50 1212 9.2 0.18 0.36 0.009 0.59
20 68 2310 17.4 0.33 0.68 0.017 1.08
30 86 4195 31.7 0.61 1.24 0.030 1.90
40 104 7297 55.1 1.06 2.15 0.051 3.20
50 122 12210 92.2 1.8 3.60 0.083 5.19
60 140 19724 149 2.9 5.82 0.13 8.13
70 158 30866 233 4.5 9.11 0.20 12.3
80 176 46925 354 6.8 13.8 0.29 18.2
90 194 69485 525 10.1 20.5 0.42 26.3
100 212 100446 758 14.6 29.6 0.59 36.9
120 248 196849 1486 28.6 58.1 1.10 68.7
140 284 358137 2704 51.9 105.7 1.91 119
160 320 611728 4619 88.7 180.5 3.11 194
180 356 990022 7475 144 292.1 4.80 300
200 392 1529627 11549 222 451.2 7.11 444
  • 1 lb/ft3 = 16.018 kg/m3
  • 1 kg/m3 = 0.0624 lb/ft3
Example - Saturation Pressure Water Vapor
The Saturation pressure of water vapor in moist air at dry bulb temperature 25 oC can be calculated:
First, convertion from °C to K:
( 25 °C) + 273 = 298 (K)
Then Eq. (1) is used:
pws = e(77.3450 + 0.0057 (298 K) - 7235 / (298 K))/ 298 (K)8.2
= 3130 (Pa)
Air Psychrometrics
Air - Drying Force
The drying force of air depends on the air moisture holding capacity and the water surface to air evaporation capacity.
Dry Air Thermodynamic and Physical Properties – Density, Specific Heat, Viscosity
THe essential thermodynamic properties of dry air like specific heat, ratio of specific heats, dynamic viscosity, thermal conductivity, Prandtl number, density and kinematic viscosity at temperatures ranging 175 - 1900 K.
Humid Air and the Ideal Gas Law
Pressure, temperature and volume in a perfect ideal gas like moist air (air with water vapor).
Liquids - Vapor Pressures
Vapor and saturation pressure for some common liquids.
Moist Air - Degree of Saturation
Humidity ratio of moist air to humidity ratio of saturated moist air.
Moist Air - Density vs. Pressure
Density of moist air vs. pressure ranging 75 - 1000 mmHg.
Moist Air - Mole Fraction of Water Vapor
Mole fraction of water vapor is the ratio of water molecules to air and water molecules.
Moist Air - Partial Pressure and Daltons Law
The pressure in a mixture of dry air and water vapor - humid or moist air - can be estimated by using Daltons Law of partial pressures.
Moist Air - Psychrometric Table for Pressure 29.92 inHg
Dry and wet bulb temperatures, saturation pressure, water vapor weight, specific volume, heat and more.
Moist Air - Vapor Pressure
Vapor pressures vs. dry and wet bulb temperatures in moist air.
Removing Heat with Air
Calculating heat removed with air by measuring the wet bulb temperature.
Water - Saturation Pressure and Specific Weight vs. Temperature
Vapor pressure and specific weight of water at temperatures ranging 32 to 212 oF - Imperial Units.
Water Vapor Saturation Pressure: Data, Tables & Calculator
Wet Bulb Globe Temperature (WBGT)
The Wet Bulb Globe Temperature can be used to measure the general Heat-Stress index.
