The density of humid air varies with water content and temperature. When the temperature increases a higher molecular motion results in expansion of volume and a decrease of density.
The density of a gas, dry air, water vapor - or a mixture of dry air and water vapor like moist or humid air - can be calculated with the Ideal Gas Law.
Density of Dry Air
The density of dry air can be calculated
ρa = pa / Ra T
= 0.0035 pa / T (1)
ρ a = density dry air (kg/m3)
pa = partial pressure of dry air (Pa, N/m2)
Ra = 286.9 - individual gas constant of dry air (J/kg K)
T = absolute dry bulb temperature (K)
Density of Water Vapor
The density of the water vapor can be calculated
ρw = pw / Rw T
= 0.0022 pw / T (2)
p w = partial pressure of water vapor (Pa, N/m2)
ρ w = density of water vapor (kg/m3)
Rw = 461.5 - individual gas constant water vapor (J/kg K)
Density of Moist Air - an Air Vapor Mixture
The amount of water vapor in air influences the density. Water vapor is relatively light compared to diatomic Oxygen and diatomic Nitrogen - the dominant components in air.
When vapor content increases in moist air the amount of Oxygen and Nitrogen are decreased per unit volume and the density of the mix decreases since the mass is decreasing.
Based on specific volume of moist air the moist air density can be calculated
ρ = 1 / v
= (p / Ra T) (1 + x) / (1 + x Rw / Ra ) (3)
v = specific volume of moist air per mass unit of dry air and water vapor (m3/kg)
x = mw / ma = specific humidity or humidity ratio (kgh2o /kgdry_air )
mw = mass of water vapor (kg)
ma = mass of dry air (kg)
p = pressure in the moist air (Pa)
The density of dry air with the same total pressure p as in the mixture (dry air + vapor partial pressure) - can be calculated as a reference as
ρref = p / Ra T (4)
ρref = reference density of dry air with the same pressure as in the air vapor mixture (kg/m3)
The density of moist air related to dry air can be expressed by combining (4) and (3) as
ρ = ρref (1 + x) / (1 + x Rw / Ra ) (5)
The gas constant ratio between water vapor and air is
Rw / Ra = (461.5 J/kg K) / (286.9 J/kg K)
= 1.609
and inserting the ratio in (5) the density of moist air related to dry air can be expressed as
ρ = ρref (1 + x) / (1 + 1.609 x) (6)
Note! As we can see from (6) - increased moisture content reduces the density of moist air - dry air is more dense than moist air.
• Air Psychrometrics
• Densities
• Gases and Compressed Air
Using steam to humidify air.
Air - Humidity Ratio
Air and Steam Mixtures
Air in the steam will lower the surface temperatures in heat exchangers - and less heat will be transferred.
Dry Air Thermodynamic and Physical Properties – Density, Specific Heat, Viscosity
THe essential thermodynamic properties of dry air like specific heat, ratio of specific heats, dynamic viscosity, thermal conductivity, Prandtl number, density and kinematic viscosity at temperatures ranging 175 - 1900 K.
Humid Air and the Ideal Gas Law
Pressure, temperature and volume in a perfect ideal gas like moist air (air with water vapor).
Mixing of Humid Air
Moist Air - Degree of Saturation
Humidity ratio of moist air to humidity ratio of saturated moist air.
Moist Air - Density vs. Pressure
Density of moist air vs. pressure ranging 75 - 1000 mmHg.
Moist Air - Partial Pressure and Daltons Law
The pressure in a mixture of dry air and water vapor - humid or moist air - can be estimated by using Daltons Law of partial pressures.
Moist Air - Psychrometric Table for Pressure 29.92 inHg
Dry and wet bulb temperatures, saturation pressure, water vapor weight, specific volume, heat and more.
Moist Air - Specific Volume
Specific volume of moist air is defined as the total volume of humid air per mass unit of dry air
Moist Air - Specific vs. Relative Humidity
Specific humidity of moist air vs. relative humidity, water vapor and air density.
Moist Air - Water Vapor and Saturation Pressure
Saturation pressure of water vapor in moist air vs. temperature.
Moist Air - Weight of Water Vapor
Weight of water vapor in air
Saturated Salt Solutions - Controlling Air Humidity
A salt solutions can be used maintain a particular value of relative humidity.
Wet Steam - Specific Volume
Wet steam and specific volume.
